Question about Dell Inspiron 1501 Notebook
My inspiron 1501 will not turn on
After i changed he AC adapter on my inspiron 1501 it has not turn on. At first the lights came on but it shut down right away. It did it 2 times.
Please follow these steps.
Here is the service manual. Follow the steps in this and let me know what exactly happens.
These are the devices you need to remove by using the manual. the instructions are given in the manual.
first before you remove any parts
try to run a diags by pressing Fn+power button together and turn on the laptop.
Fn found on the lower right of the keyboard.
1.Hard drive.
2.CD Drive.
there are 2 memory cards and 2 memory slots in this laptop.
Remove both of them.
try each card in each slot and make sure that there is only 1 memory card in the system at a time.
Post your results.
also post what are the lights that are on.
check num lock, capslock and scroll lock lights and post the results
I can tell you if any parts have gone bad and if gone bad how you can buy and easily replace those.
thank you
Dell Laptop Expert
Posted on Jan 09, 2009
Hello, I have a Dell Inspiron 1501. It has shut down on me in the middle of my session and now will not come back on. I plugged in the adapter for it to charge a few mins then the charging light shows but...
Don't think as a battery error, if you can use without the battery ,pls check with ac adapter without battery.because there may be a short circuit with charging unit or power side, you have to test before blow up the unit. if blow up chip or mos fet, it will be hard to repair.
May 05, 2017 | Dell InspironTM 1501 Notebook
Dell inspiron 1501 cannot indentify ac adapter
try this first. drain the flea power. remove batter and ac adapter. press and hold on the power button for 10 seconds. plug back ac adapter and battery. go online to then download the latest bios update.
once you reach the dell support site select on support for home users. then drivers and downloads. enter the service tag.
when the list of drivers and updates are listed make sure you selected the correct operating system. look for the BIOS then download it via browser. (do not download the manager)
after the download run or install the update.
If all fails. try a diff ac adapter if same problem message appears then replace the motherboard. else replace ac adapter.
Mar 30, 2010 | Dell Inspiron 1501 Notebook
It wont stay power up;and screen stays black; and shuts down after a second' please help'''''
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron 1501 Notebook
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Sep 07, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
Jun 04, 2009 | Dell Inspiron 1501 PC Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
No power for laptop Inspiron 1501
try removing the battery and connect the adapter then switch you pc on ,if it works, then you have to change your battery, else you have a bigger problem and need professional, if you are ask for more help.
Dec 02, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
121 people viewed this question
Alun Cox
