Question about Kenmore 22422 Top Load Washer
70 series washer will not fill with cold water, only with hot wat
If I switch the hoses the washer will fill with cold water on the hot setting and hot water on the cold setting but when I put the hoses back to normal and set the washer to the cold setting nothing comes out. This makes no sense to me.
  • Kenmore Master
  • 8,220 Answers
Hot/cold selector switch replacement imminent.
Posted on Jan 08, 2009
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
185 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
