Question about HP Photosmart 8050 InkJet Printer
HP Photosmart Printer, Mac won't recognize with USB
I have a Photosmart Printer it's an 8049.  I had it plugged in to my iMac, which is two years old.  It was working fine, and then yesterday I moved my computer to a different wall in my office.  I plugged everything back in, and replaced the ink cartridges.
I tried to print and it won't print anything out.  The printer printed a test page when I put in the ink cartridges, so I know the printer works still.  (It just worked yesterday...too)
On the Mac the icon pops up saying it's printing, then it says connection error, check connection.  So I unplugged everything, plugged it back in.  Still didn't work, and then I did all of the Mac troubleshooting, still didn't work.  I tried a different USB cord, nothing.  Then it spit out half of the page I had requested to print and stopped again.  It still won't print anything tonight.  I even unplugged both for 20 minutes, and let them reset.
I followed all HP directions for troubleshooting that they had online.  I then tried the printer on my laptop, and the Mac laptop won't pick it up either.  So I guess it needs something reset or something?  I checked my USB and it's not recognizing it.
I uninstalled the printer from the computer, and then re-installed all software.  Now the software can't even pick up the printer to re-install.  What do you think I need to do?
  • bmeg Mar 08, 2009
    I had a paper jam and after that my computer can't find the printer.
  • Anonymous Apr 13, 2009
    when i plug the usb of the HP photosmart D7200 Printer Series into my Macbook, nothing happens, and i tried searching around for it, but nothing happend
  • 4 Answers
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Posted on Feb 17, 2009
3 Suggested Answers
cene765
  • 787 Answers
SOURCE: my computer wont recognize my hp photosmart 8049
Try reinstall the driver or replace cable. In worst case there is defective logic board assembly in your printer.
Posted on Sep 29, 2009
SOURCE: my HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: 4.1.1.00.1332 (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
Posted on May 09, 2009
Can't print from HP 2540 aio to my Imac PowerPc G5 OS X 10.5.8 The Imac keeps telling that the printer is offline.
A quick look at the HP web site for this printer shows that it only supports Max OS X 10.6 and later. These versions only support the intel processor based macs. Your PowerPC mac is, unfortunately, obsolete as far as Apple and the peripheral manufacturers are concerned and is not supported.
Dec 19, 2013 | HP PhotoSmart 7350 InkJet Printer
IMac freezes on start-up and won't unfreeze until I unplug USB-connected hardware.
Mine the same, so don't connect until installation complete, then switch on the or plug in the item
Jun 22, 2012 | Apple iMac Z0GF0005F Desktop
Hp c4580 on mac 10.6 won't scan
Based on the information you gave this may help:
Go to 'system preferences'
select 'print and scan'
Above the picture of the listed printer select 'scan'
Then select 'open scanner'
Follow onscreen directions from here.
Jun 08, 2012 | HP Photosmart C4580 All-in-One InkJet...
My computer wont recognize my hp photosmart 8049 printer
u need to install its software that comes with it in a cd
Sep 29, 2009 | HP PhotoSmart 8049 InkJet Printer
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
I can't scan anything on my HP PHOTOSMART C4345 All-In-One
Try this: Power down the computer and printer, connect the usb to a different usb port. Reboot. The Mac should register the changed location.
The older apples used to be very sensitive to port selection and peripherials serviced. Perhaps they still are.
Regards
apeal
Aug 21, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
My iMac says my HP Photosmart 8050 is not connected
the USB port on the back became loose. its common on that series. the ONLY thing you could do, is to take apart the printer (find the screws, they're torx, you'll figure it out while you watch TV) and once you get to the main board, buy a soldering iron at the $1 store and heat up the connections. At most, you may have to buy a little bit of solder for $3 at radio shack. once you do that, the printer works perfectly for a very long time!
Jul 08, 2009 | HP Photosmart 8050 InkJet Printer
HP PHOTOSMART C4280 ALL IN ONE WHEN USING IMAC 10.5.7, PRINTER SHOWS MESSAGE USB NOT CONNECTED
You need to try isolating the problem first.
1. Try connecting the USB cable into different USB port of your Mac Leopard.
2. Make sure that your computer could detect other USB devices.
3. Try connecting the printer into different computer to see if the printer would be detected or not.
4. Use different USB cable.
If you get the same problem, you need to contact the printer manufacturer. I believe that it is more on physical connection.
Have a great day!
Jun 22, 2009 | HP Office Equipment & Supplies
My macbook wont recognize my hp camera, i installed the software that came with it but it still wont even recognize that its even connected.
your camera should work fine with the built in iPhoto software, simply launch the program and connect your camera, you should be able to download your pictures immediately.
Feb 22, 2009 | Apple iMac 24" Desktop
USB Not Connected
first..check through the HP icon here, to see if that printer has a IMAC driver
that might get you there...I'm sure that the USB ports on your IMAC are working..
you can check them with some other device, of course.
Mar 28, 2008 | HP PhotoSmart C4280 Laser Printer
HP Photosmart 8050 InkJet Printer Logo
2,145 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
