You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
SOURCE: When I turn my water faucets off the pipes CLANG,
What has happened is the water pressure to the house has increased and you are getting a hammering type noise. Try reducing the flow out at the meter. Also, there is a device called a hammer arrester that you can install on your washing machine connection. It's supposed to reduce or eliminate this noise. Depending on where you live, the water utilities may have replaced one of their pumps to a higher demand pump to meet growing populations. This is what can start this. Hopefully I have answered your question and please don't forget to rate my service to you. Have a great weekend.
SOURCE: can't remove broken PVC pipe from bathroom wall...need to install new faucet
there should be an acess pannel there somewhere too get too it ,if not then you will have too cut the wall and replace the pipeing
SOURCE: My master bathtub is leaking
Yes the weight of someone in the tub plus the water can push the tub down far enough to cause the leak.
Unscrew the flange in the tub that holds the drain to the tub. Get some plumbers putty and make a bead to fit between the tub and flange.
Make sure the rubber gasket is clean ..use a bit of plumber's putty on this as well. Get an assistant to stand in the tub while you snug things up.
Snug it up tight.... replace if the threads are stripped as you said.
Plus if your house is less than a year old, I'd talk to the contractor/builder if possible about warranty work...most reputable builders will cover their work for the first year.
SOURCE: pull down shower diverted works, but allows bypass into tub
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
aquasource kitchen faucet (coach series)plastic handle broken.can it be replaced
