Question about Goodman GMS90703BXA Heater
FURNANCE WONT FIRE UP GOODMAN GMNT12-5D - Goodman GMS90703BXA Heater
  • 1 more comment
  • MTRAY768 Jan 12, 2009
    Same problem with package unit but ignitor will spark a little but not long enough to start unit
    Thanks. T
  • Paul Carew May 11, 2010
    does the fan run do you have power to it ? as above any lights come on ?
  • wmnixdorf May 11, 2010
    what does it do? anything? lights come on?
  • 1,420 Answers
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
Posted on Feb 20, 2009
How to fix goodman furnance A30-15 the blower wont turn on ?
Check capacitor, cheap replacement and easy to do, also spin blower wheel by hand to see if it moves freely. If so could be Cap. U can also try canding blower speeds to see if one of the speeds burnt out. Warranty??
Jun 09, 2014 | Goodman Heating & Cooling
Hi,my name is julio i have a problem with my goodman furnance,the furnance run for 10 or 15 minutes and then shut off and come back again for 5 minutes keep do in on and off on and off and then shu off...
it is probably hitting the high limit switch possibly.
Is your filter clean?
Are all the vents in the house full open?
Is your furnace vent (flue Pipes) clean and unobstructed?
Jan 07, 2011 | Goodman GMS90703BXA Heater
The furnance ignites for about ten seconds the right befor the blower comes on the furnance goes out. This repeats itself over and over until the unit shuts itself down.
Take out the flame sensor and clean it with a piece of sand paper or emery cloth and put it back in and this should get sustained flame.2e77348.jpg
Feb 25, 2010 | Goodman GMS90703BXA Heater
Goodman Dependable 92, ignitor and fan comes on for 3 seconds, furnance does not turn on. Goes through 3-4 cycles, then shuts down furnance. If it is the flame sensor, where can one buy parts?
Do the burners come on? If so then yes it probably is the flame sensor if not then there is another issue not the flame sensor. The flame sensor could just be dirty take the flame sensor out and clean it with a piece of emery cloth or lite sand paper and put it back in and this should get the burners to stay on.
Feb 05, 2010 | Goodman GMS90703BXA Heater
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
GDS80904BXBC WILL FIRE FOR A FEW SECONDS AND THEN FUSE BLOWS
if it is the fuse on the furnace board,disconnect all low voltage wires to r-g-w-y-c.make sure you label where they go.jump out red to white if unit comes on and runs,chances are you have a bad t-stat wire or tstat.
Dec 29, 2008 | Goodman GDS80904BNA Open Flame Heater
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
519 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
