Question about Braun Tassimo Espresso Machine/Coffee Maker
Yellow light comes on to heat water, but does not change to green
I turn the power light on. The machine goes to the yellow light, but stays there, will not proceed to the green light.
  • Anonymous Jan 14, 2009
    I have the same problem and my machine is only a month old
    Problem Solver:
  • 4 Answers
I would try opening and closing the disc enclosure latch-- this triggers the machine to re-read the barcode and start a new cup of beverage. If the machine perceives that water needs to be heated more, the yellow light to should flash and the cycle to green when ready. If the water is already hot enough, when you close the latch, it will flip right to green.
Give this a try.
Also see my solution to my own problem with the water reservoir: http://www.fixya.com/support/t1267835-braun_tassimo_model_type_3107_brew
Gazzer.
Posted on Jan 22, 2009
  • Gail Rude
    Gail Rude Jan 06, 2014
    It is now making sounds and flashing green the +cup light so hopefullyit is going to work thanks I reopened the disk lid as suggested blinking lots but still no tea coming out/water now stopped again
Dolce gusto kp2100 won't stay on
in the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
Oct 07, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
-it is a power problem. -i turn on my ps3 system using the main power button on the back of the console and the red light comes on in front. -i then touch the standby button in front and the red light...
You can fix it yourself. The CPU was to hot and the solder has come off. Bad part is the solder is under the CPU and must be heated up. It is lead free so it needs more heat then lead and you need to add flux. I would start by getting the board out. Remove the thermal paste off the CPU. Add flux with a flux pen. You want to get the flux under the CPU so you might want to tip it on its side. After you have a good amount of flux under the CPU you want to start to heat the parts around the CPU. I would use a heat gun with temp. settings. You first want to heat around the CPU to keep solder on the other parts from cracking. You dont want to over heat the parts. After you preheat the board you want to heat the CPU. It needs to be around 400 or 500 degs f. a good 15 or 30 sec. keep moving the heat gun. After heating the CPU you want to start the cool down. Same as warming up the board but you want the board to cool down slow. After all this you want to add New thermal paste to the CPU. This helps transfer from the CPU. This is a must because your PS3 is overheating as it is. After you do all this some people say it only works for 2 to 6 weeks. Its all on how you fix the board and how good of a job you did. I would back up your hard drive. Then hope for the best!! good luck and i hope this helps you out.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
Hi
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3's power light goes from green to yellow and then to red and then swithchs off? anyone with any ideas wats wrong? many thanks
ps3 . when i turn it on the green light comes on then goes flashes yellow then goes red and will not come on
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Yellow Light
Emachines are bad for having failed power supplies and motherboards. Test your power supply, watch this video.
http://www.metacafe.com/watch/729606/how_to_test_your_computers_power_supply_psu/
Aug 03, 2009 | E-Machines eMachines Desktop PC
Braun Tassimo Espresso Machine/Coffee Maker Logo
1,484 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
