Question about Apple iPod touch
My gps doesnt work
It says to charge when the batteries full
  • 30 Answers
Try to update it and then see if it still has that problem
Posted on Jan 07, 2009
My gps doesnt work without the charger???!!!!
If its not charging the battery with the 12 volt cigarette cord, the meter will say full even though the battery is dead. This is a common problem with GPS Units with the USB as a charging port. If the GPS Unit is still under warranty, i would send it back to magellan or whereever you bought it, the sooner the better. I believe that you GPS is defective or in need of repair. Hope this helps.
Jun 25, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
How do i know my xxl 540s battery charge full?
To know if your tomtom is fully charged. Unplug the tomtom from the power source and you will see the battery meter, if it is full or not, because while it is charging, it is the power source that is working so the battery signal will not come up. Unplug it and you will see the battery meter.
Hope this was able to solve the problem.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
Battery doesnt stay charged like it used to ? approx three years old , works ok with charger plugged in
The battery has come to the end of its service life, you will need to replace the battery. Contact Nextar at www.nextar.com for information.
Jun 17, 2010 | Nextar I4-BC GPS Receiver
Battery losing charge whilst plugged in to cig lighter
I have the same problem, when the battery goes dead, it seems to do so instantly vs. just holding the charge for less time. You can replace the battery, but with the prices coming down and the fact that the map upgrades cost what they do, I'm thinking it's more cost effective to just buy a new GPS.
Apr 18, 2010 | Tomtom ONE 3rd Edition GPS
Doesnt hold charge
The battery is worn out. You need to return it to the manufacturer so they can install a new one. Even rechargeable batteries wear out eventually. If they are in constant use, discharge/recharge, you can reckon on 5 years. If they are left for long periods discharged, or not used, then the life reduces dramatically.
Dec 05, 2009 | Tomtom GO 920 GPS Receiver
Unit won't remain powered-up
You are absolutely correct Jim. Low Battery
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Dec 25, 2008 | Garmin nuvi 260W GPS Receiver
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Apple iPod touch Logo
15 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
