Question about GoVideo Go Video DVD/VCR Combo
Go Video VCR/DVD Combo DVD drawer won't open
Had trouble getting disc to eject. It finally did, without any intervention. But now drawer won't open at all. Otherwise, unit seems to be okay. There is a "whirring" noise when the eject button is pushed, as if it's trying to open but can't - maybe a broken belt? Can't figure out how to open this unit. Technical support no longer available from the manufacturer. Purchased about 6 yrs. ago.
  • 1 more comment
  • Anonymous Jan 17, 2009
    Same problem. Drawer won't open. It's a couple of years old but probably used less than 10 times. Why????
  • RJ1989 Jan 22, 2009
    Dvd door would not open all the way after playing a music cd. I finally got the cd out and a round belt came out as well.
  • BadGoVideo Feb 04, 2009
    I have the same problem. The DVD drawer won't open. I only used the VCR to DVD copying for about 50 times.
    From NoMoreGOVideo
I opened the back & saw that there were no belts, etc. Put it all back together again, held the DVD door open, focused a bright flashlight into the opening, pressed eject, and saw that there was some sort of little lever(?) on the right that wasn't engaging. So I pushed it with a small sharp object while simultaneously pushing the eject button, and the tray ejected! I will take a chance and try to copy a video to the DVD again, hoping that when it is done I will be able to get the DVD to eject. I have only a few more family videos to copy (luckily I had already done most of them), so hopefully it will continue to work until I have finished the job. Thanks for everyone's ideas & help! I would buy another one of these video -to-DVD machines if it were available, but alas, the only ones I've seen are about 4 times as expensive as this one, and not worth it for the small amount of copying I have left to do.
Posted on Jan 31, 2009
  • 73 Answers
There are drive gears in the unit and it should not be making a whirring noise. It usually ejects in a second, and thats all of the noise you should hear. There are no belts, or at least not in that portion of the transport. Its probably a plastic gear that has worn down from years of use, or broken from someone trying to force it open.
With the prices of DVD players these days you would not want to have it serviced assuming it is out of warranty. Service is going to cost upwards of 80+parts, whereas I saw a DVD player the other day in Wall mart for 32.00.
Best of luck and Happy New year!
Posted on Jan 09, 2009
DVD drawer will not open on my vr320
Feb 17, 2017 | Televison & Video
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
turn the unit on, set to dvd and turn off. then press the dvd open/close button, it should turn on and open without reading the disc.
Mar 22, 2010 | GoVideo Go Video DVD/VCR Combo
Try using paper clip to open your dvd drawer.
Mar 03, 2009 | GoVideo Go Video DVD/VCR Combo
Go video ht2015
there's a black band that connects the motor to the pulley that opens the drawer.....this band has been burst.
easy to replace by using a small rubber band.
just finished doing this with my one.
now the drawer opens and closes ok.
Oct 23, 2008 | GoVideo Go Video DVD/VCR Combo
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo Go Video DVD/VCR Combo Logo
329 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
