Question about One For All URC-3021 Remote Control
Can't read the keys on this remote
I need a sharp close up photo of this remote because the keys are so worn that the labels on the keys are worn off. Please Help
Thank You
  • n1leu Jan 08, 2009
    Cool! I found the manual for this unit (all for one urc 3021) in .pdf format thanks a ton! 73
  • Michael Fisher
    Michael Fisher May 11, 2010
    Please Specify Remote Model.
  • 716 Answers
Http://www.retrevo.com/support/One-for-All-URC-3021-Universal-Remotes-manual/id/2784bh227/t/2/
Click Key Charts And It Will Show You A Close Up.
Hope This Helps
Posted on Jan 07, 2009
Where's the input keys in the remote control located?
The input key is usually located on the remote, it might also be labeled Source key also. Different manufactures use different labels to label their keys, check the left or right side panel for input/on and off keys as well as source key
Sep 09, 2011 | Sharp LC32L400M TV
On our Sharp 27' box television :) there is a solid black box on the bottom of the screen, so you only can see the top half and the sides of the picture!
Hi: Check your closed caption mode you have closed caption text selected. Look on yoiur remote for a button labeled CC or look in the menu for closed caption and turn or select the off option.
Mar 17, 2011 | Sharp Televison & Video
JAM LABEL
1. Turn the printer on and make sure that the LCD display reads 'ON LINE'.
2. Press the PAUSE key once. [The display will read 'PAUSE'.]
3. Press and hold the PAUSE key until four or five labels feed forward.
NOTE: On some models, pressing the pause key will change the LCD display to 'TRANSMISSIVE'. If this happens, repeat step 3.
4. Press the RESTART key. The printer will go back ON LINE.
5. Open the print head and reposition your labels, so that they are ready for printing. Close the print head.
Nov 17, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
My projectors keys are locked. I do not have the remote for the projector. How do I unlocked the keys and turn the projector back on? Thank you
You don't need the remote. I lost the remote years ago, so it forced me to read the manual. When powering up the unit (after it says "wait...", press and hold the "On" button. It will tell you the keys are unlocked.
Great product, I've had mine now for 7-8 years with 0 problems.
Sep 09, 2010 | Sharp Office Equipment & Supplies
Sharp 2618
This problem on your copier heater section,I mean bnormal temparature.So you can reset it,.
Press your copier panal board button
C (Clear) Photo(exproser bytton) C Photo
Press 14 Make up and down arrow key press print key(Start key)
C>Photo>C>photo>14>print key
all are ok
Apr 22, 2010 | Sharp AL 1631 Copier
I am trying to turn on my closed captioning on my 19'' orion tv but dont see it... how do i turn it on
Usually you can turn on the closed captioning from the remote. There (should) be a button labeled "cc" that you just need to press once or twice until you get the closed captioning style you want. If your remote doesn't have this button, or if you don't have a remote, you could try two things. First, you could try (i'm not sure if this would work) going into the tv menu itself and searching for the closed captioning part, or you could just go out and buy a universal remote that has the "cc" key. I hope this helps! Sincerely, Der Strom
Apr 08, 2010 | Televison & Video
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Dec 30, 2008 | Televison & Video
Clossing Door
If the door closes by holding the wall button you have a photo eye issue. Check your photo eyes for proper operation.
Sep 05, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
One For All URC-3021 Remote Control Logo
163 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
