Question about Brother MFC-8640D Printer
Need free paperport
I need paperport for free to my borther printrer..where can I get it?
  • 404 Answers
Hello!
Whenever I need Software for Free I go to www.cnet.com I've always found what I needed there.
Good Luck!
Paul 'W'
Posted on Jan 07, 2009
Finding my erased paperport program
Try searching that name in your download file. It should be there or it could be in your programs. Open control panel and search for that program, you will find it. Thank you Malinda and please leave feedback. Let us know?
Jul 13, 2016 | ScanSoft Nuance PaperPort 11 for PC
Free software paperport
Sir/Madam
PaperPort installs a PaperPort Black and White Image driver and a PaperPort Color Image driver. These drivers allow you to import documents onto the PaperPort desktop via the print feature.
If one or both of the drivers are missing, follow the steps listed below to run the PaperPort repair program. This program will re-install the drivers:
  1. Open the Control Panel.
2.Open "Add or Remove Programs".
3.Locate and select PaperPort. Click the "Change" button.
4.When the PaperPort InstallShield wizard appears click NEXT.
5.Select "Repair" and click NEXT.
6.Click "Install" to begin the repair process.
7.When the installation is completed a window stating "InstallShield Wizard Completed" will appear. Click FINISH.
8 The repair process is now complete and the drivers will now be installed.
If your question was not answered, please Go To Below URL for Brother Printer Troubleshoot,
OR
If You Still Need Assistance Then Follow US For On :
Brother Printer Support
Feb 03, 2014 | Brother MFC-290C Printer
I use PaperPort 8. When I try to print to PaperPort or PaperPort Color, everything appears to work fine but the item doesn't get to the PaperPort folder. this happened once before and someone at FixYa...
http://www.fixya.com/support/t763517-paperport_selection_printer_but_item
http://nuance.custhelp.com/app/answers/detail/a_id/5852/~/changing-the-default-folder-location-for-paperport
https://support.brother.ca/app/answers/detail/a_id/86451/~/how-do-i-change-the-folder-to-save-scanned-documents-in-paperport-12se%3F
http://paperport.helpmax.net/en/changing-paperport-options/changing-paperport-options/changing-the-default-folder-name-and-color/
May 01, 2017 | Computers & Internet
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
Paperport 11 crashes as soon as I open it. This is a recent problem, and there is no apparent reason for the change. I'm running Paperport on Windows XP. THis is the message that keeps coming up:...
Paperport 11 crashed as soon as I open it. "PaperPort has encountered a problem and needs to close. We are sorry for the inconvenience." I found that the problem was caused by a corrupt file in the default directory. I moved all the files from that directory to a new one and the problem was fixed. I transferred the files back 3 at at a time until I found the bad file. It was a PDF file not created by PaperPort.
NO help from Nuance
Ranwin@gmail.com
Jun 26, 2009 | ScanSoft Nuance PaperPort 11 for PC
I cant find the software for my printer pls help me out
Help is here!
I presume you need to locate Paperport and possibly drivers? www.brother.com for driver (support & downloads) www.cnet.com for latest paperport. FREE!
Good Luck!
Paul'W'
Please don't forget the Fixya button!
Jan 24, 2009 | Brother DCP 115C All-In-One InkJet Printer
I am trying to install Paperport 9.0, which I once had on another computer. Each time the Wizard stops installation with an 'Paperport 9.0 Inside Information' with an error sign: Internal Error 2723 New...
Unfortunately, the newer version of PaperPort has left the traces in the registry. You can try to manually search and edit the registry or try one of the PaperPort Removal Tool options.
Backup your computer before trying the following steps. To edit the registry, make sure that you are using the account with Administrator privileges. Click Start and choose Run (for Windows versions 7 and down). For Windows 8, 8.1 and 10, click the Start button and type run. (With Windows 10, you can also right click on the Start button and choose Run.) Type in regedit. Use the Edit > Find command to search for PaperPort keys. Export the key to a file with the File > Export command. Then delete the key. You will need to restart the computer after closing regedit to load the new registry.
Alternatively, try one of the Nuance PaperPort removal tools. See http://nuance.custhelp.com/app/answers/list//p/26/kw/What%20are%20you%20looking%20for?#s=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 . for links to the removal tool for various versions of PaperPort. Note: if you have a CD with PaperPort 9, it will have the PaperPort 9 removal tool in a sub-directory. You will need administrator privileges to run the removal tools. This is a much safer option than regedit for most users. However, you need to know which version of PaperPort was installed. I'd try the PaperPort 9 unistall tool first. The last time PaperPort was installed, the system probably checked for updates and some patches were applied.
I hope this helps. You may want to clear the temporary files as well by using a Disk cleanup option. From File Explorer, right click on the hard drive icon and choose Properties. In the General tab, you will see an option for Disk Cleanup. After doing a basic cleanup, consider going back and press the Clean Up System Files button to get rid of more temporary files.
Jan 20, 2018 | Office Equipment & Supplies
Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
Jul 18, 2008 | Epson Perfection 1250 Flatbed Scanner
Sharp al-1551
I believe at the company I work we use Nuance's PaperPort (formerly known as Scansoft PaperPort)
If you are interested, you can download a trial version here:
[Nuance PaperPort 11 Trial]
I hope this works for you, there might be free alternatives though.
Please rate this solution.
Greetings,
DarkNeogen.
Jan 25, 2008 | Sharp AL-1551 Laser Printer
Brother MFC-8640D Printer Logo
235 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
