My gateway nv52 doesn't charge when it is plugged in. i bought a brand new battery and a brand new charger, so i know that those aren't issues. the battery is dead now and i can't figure out how to charge it.
Yes, it is most likely that there is something wrong with your laptop dc jack or motherboard. Either replace the dc jack or get it repaired. If it can't change the situation, that means your motherboard need to be exchanged.
http://www.chargerbuy.com/intocircuit-gateway-nv52-65w-ac-adapter-19v.html
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
SOURCE: gateway laptop MX8734 Notebook will not power up
If it is plugged into the power cord, it will boot up. Radio Shack and Batteries Plus has good deals on batteries and carries most brands.
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
SOURCE: Gateway NV52 Laptop charger sound.
I don't know if this will work with Vista but in Windows 7 you can go to the speaker icon in the taskbar and click on the icon above the volume control. This will take you to the sound properties. Click the levels tab and mute the PC speaker. This worked for me.
SOURCE: Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
