Question about Dell 3400MP Multimedia Projector
Green screen when projector hooked to laptop
This problem just started occuring, have hooked up to two different laptops and the projection screen reflects a green cast however laptop screen is the normal blue. Ran the color check on projector and all colors were true. Any ideas?
Projector is a
Dell 3400 MP
Thank you.
5 Suggested Answers
  • 5 Answers
SOURCE: Epson projector issue
I've found my solution. My troubleshooting info said to go to "signal" and make sure that "auto" was turned on. However, I couldn't find "auto" when I first tried. There are two places where signal comes up. The second one is under "set-up" and that is where you turn "auto" on. It works perfectly now. I hope this helps. For the icons, make sure you have "mirror image" turned on in your displays preferences if you're on a Mac. Good luck.
Posted on Jan 06, 2008
Marrie
  • 563 Answers
SOURCE: change color setting
Hi chatnola
The only way to access these settings is through the Service Menu , now if the tech support doesn't want to help you , rather send go to dell.com and send them a e-mail with your request on how to enter the service menu.
Posted on May 06, 2008
  • 84 Answers
SOURCE: Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Posted on Sep 25, 2008
SOURCE: Hitachi CP-S235 Data Projector - yellow tint to projected picture
Replaced cable and the problem was solved.
Posted on Feb 12, 2009
vortash
  • 431 Answers
SOURCE: Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
Posted on May 10, 2009
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
Green projection
The interface with the laptop is not set correct. Open the screen settings and check the optional monitor settings. check configuration as specified on the projector.- since model is not mentioned.
Jan 10, 2012 | Office Equipment & Supplies
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
Projector has image on screen but cannot get connectrion to laptop to project pwerpoint
Be sure you have the right input selected. You might try Auto Search. Then toggle the laptop using the F8 or proper function key to display the output to the projector or in both places. Sometimes the laptop must be hooked up to the projector before the laptop is turned on. Hope one of these works.
Feb 09, 2011 | InFocus Office Equipment & Supplies
Can't project SONY VAIO laptop onto screen with NEC projector
Change the chord with a chord with a new one preffered by that laptop.
Aug 14, 2009 | Computers & Internet
Green ball on projector screen
I have connect to hp laptop with projecter but showing error mouse not working in laptop.mouse is shoing in projector
Oct 31, 2008 | Sanyo PLC XU35 Multimedia Projector
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
554 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
