Question about Garmin nuvi 350 GPS Receiver
Display is very dark
I borrowed this from my daughter and I can't see the display very well. have brightness on highest setting. Also have hard time turning it on.
  • Garmin Master
  • 2,130 Answers
If the brightness control is turned all the way up and the screen is still dark, then the LCD display is defective. Probably a problem with the backlight.
To turn on, you have to press and hold down the on/off power button until the screen comes on. There is a design flaw with the power switch. Please see this link for details. Too much info and pictures to paste here:
http://www.sharc.net/nuvi_power_switch_repair.htm
http://www.sharc.net/nuvi_LCD_repair.htm
- Jim
Posted on Jan 07, 2009
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
How to increase brightness without fn+f6 keys because for now the f6 key is not working
You should be able to access brightness settings from the display or power options in your control panel. there you can set the screen display and make it on highest brightness setting permanenlty so it does not dimm when unplugged from the charger.
Oct 08, 2012 | ASUS Eee PC 1000H Laptop
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Adjusting brightess on monitor
take the cover off the monitor and adjust the screw on the fly back to adjust the brightness it will be in the shape of a little knob
Apr 16, 2009 | Mr. Coffee HCLF
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Samsung u340's front screen is very dark
Probably need your brightness turned up. Go to menu, then settings, then display settings, then backlight, then brightness.
Apr 11, 2008 | Samsung SCH-u340 Cellular Phone
maybe you can adjust it in the playback....
Mar 02, 2008 | Computers & Internet
Garmin nuvi 350 GPS Receiver Logo
104 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
