Question about Gateway CX2618 Notebook
New pen not responding to computer
I just got a new pen for my tablet and it isn't responding at all. I tried to calibrate it but its like the pen doesnt exist.. what should i do? I have a Gateway tablet CX2618. Before I lost my first pen it would work intermittently with the Tablet. The replacement pen doesn't respond with the tablet at all. Why?!?!? What can I do to fix this?
Tip
Calibrating The Tablet Pc Pen
Although it may be tempting to open the box and start playing with your <b>Tablet PC</b>, one of the most important things you should do is calibrate your pen. This means spending time with the pen after a few steps to ensure that the tablet PC pen knows the touch screen is used. To do this, click Start, and the parameters of the search field type <b>Tablet PC</b>. On the list of results Tablet PC Settings and from there go to <b>Display </b>&gt; <b>Display Options</b> &gt; <b>Calibrate</b>.Follow the steps to finish the door and remember to save your settings to accept calibration.<br />
on May 07, 2011 | Tablets & eReaders
No Calibration for Wacom Pen
Sounds like your pen has problems, after so many attempts to calibrate the pen fail your tablet will automatically shut that feature off. I would suggest getting a new pen if possible and recalibrate it. The wire or fiber optic cable, which ever it has is bad to break where it bends down into the pen. Also the sensor in the end of the pen could have gone bad. I would contact the manafacturer on it and see what their tech's advise.
Mar 07, 2014 | Wacom Cintiq 13HD 13.3" Interactive Pen...
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
Apr 07, 2012 | Tablets & eReaders
Duel Monitor Cintiq Problem... pen affecting wrong monitor
under the calibrate tab in the wacom tablet properties window there is a drop down window with a list of monitors. Change that to the Cintiq
Jan 19, 2009 | Wacom Cintiq 15X Graphic Tablet
Touch screen not working
Have you tried a new battery in the stylus? They require AAAA size batteries. The first time my pen went out I thought it was the computer not responding, but it turned out to be a dead stylus battery.
Mar 21, 2008 | Averatec C3500 Tablet PC
Grip pen not responding
You could try recalibrating the tablet.  Open the tablet control panel, then click "About." Then hold Control while clicking "Diagnose..." and on the next screen -- the Diagnostics window -- you'll see a new button labled "Recalibrate..." Clicking that might do the trick.
Good luck.
Nov 29, 2007 | Wacom CINTIQ 18SX GRIP PEN (UP911E18SX)...
Gateway CX2618 Notebook Logo
286 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
