Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
TouchScreen How can I repair my touch screen which the screen which attached in the LCD is broken. Display is ok but I cannot use the touch screen. I help...
    Problem Solver:
  • 20 Answers
I would check out the website for your monitor and see if its still under warranty. Than Go from there, You could probably order the part and install it yourself.
Posted on Jan 07, 2009
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Garmin Nuvi 1300 touch screen not working
It sounds like you need your touchscreen replaced. The touchscreen is soldered to the LCD display, so the touchscreen must be unsoldered from the LCD display and a new touchscreen resoldered to the LCD display. Please do not attempt to do this yourself. You can easily damage the LCD display in the process. More information about touchscreen replacement can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Apr 21, 2013 | Garmin nuvi GPS
Broken glass on touch screen display for epson workforce 845
The touchscreen is sold as one part, you can't buy or replace just the glass. There is a capacitive layer glued to the glass that is probably damaged.
Feb 03, 2013 | Epson Office Equipment & Supplies
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My motorola lcd touch screen brokened
The screen of the a1000 model is composed of 2 parts, the lcd display and the touchscreen pannel wich are both secured in the same housing, protected by a metal frame. Even if you only broke the lcd screen (and the touchscreen is still ok) in most cases, a service center will replace the entire screen assembly. It will cost somewhere around $100-200 depending on wich service center you choose. If you try this operation in a service center, the costs will be greater because you will buy a new screen and pay the labour part. It would be greater if you can buy a second hand broken a1000 with a good display and change it yourself. A1000 and the P9xx series are very easy to dissasemble and work with. You may receive further informations and pictures if you reply with this request.
The short answer would be to try to avoid a service intervention to the phone. It will be very expensive. the a1000 model was made in 2003 so the spare parts that can be found today are expensive and hard to find. Try finding a second hand unit, you may strike a good deal with it.
hope this helps,
Bogdan
Jan 18, 2008 | Motorola Mobility A1000
Screen Calibration
I'm a french customer with a Marantz RC5400 wich has a screen LCD broken but the touchscreen is OK
I don't have the fix for your problem but I'm searching for a screen replacement at low cost...
If you always have your Marantz with the touchscreen problem, I'm interested for a deal
Thanks
Dec 06, 2007 | Marantz RC5400 LCD Touchscreen Remote...
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
51 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
