Question about RCA Televison & Video
Won't let me watch dvd
Rca j27430. it's at a hotel and i can't change the channels that are preset. me and the workers have all tried cause i wanna watch a movie and it won't let me on that channel
SOURCE: Remote Broke
Try a 'Connect-it' R/C
Posted on Aug 15, 2007
  • 1153 Answers
SOURCE: can't get TV onto the AUX channel
Do in your menu have like VCR or DVD in the option area? If so then put on vcr or dvd. Also you can look for the channel in the add or erase area and move past the channel 2 by going the other way and see if the aux or video1 comes on then simply chose it.
Posted on Sep 09, 2007
  • 236 Answers
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
  • 99 Answers
SOURCE: panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Posted on Nov 27, 2007
swampduck651
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Posted on Feb 05, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Plugging a DVD player into a RCA J25435?
The DVD player should have a coax cable output on it, You can switch its output to either channel 4 or 3. This channel 3 signal should play on your TV. murf427
Aug 04, 2012 | RCA Televison & Video
I have a philips tv,it's a 2002 model(pcw127 C121).It was originally a hotel room tv and it was given to me.I only want to use it to watch movies.I plugged in the dvd player to the two jacks in the front...
Hi Russell,
TV's most commonly found in Hotels do not have an input button which is what you would use on almost every TV set out there.
I believe that if you go to channel 2 and then channel down there maybe an AV1, AV2, Video1, Video2 or even an A1, or A0, etc.. This is what you will need to tune the TV to in order to watch a movie from the VCR or DVD player using the RCA Cables.
Unfortunately there is not a user manual online at this time, but this is where you would find it:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=PCW127C199&slg=en&scy=US
Scott
Feb 11, 2010 | Televison & Video
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
May 16, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Locked channels on a tv
You need to replace the eeprom IC in your set. Hospitality tv's ( i.e. hospital,motel etc...)have a eeprom IC that restricts programming and the use of the menu so guests can't mess up the tv picture or get unauthorized programming that they want you to pay for or just don't offer more than 27 channels. I have done this for customers before. The eeprom IC is an 8-pin IC that is right next to the microprocessor and is easy to change. Be careful soldering on an RCA board though...too much heat will lift the solder pads.Good luck!
barneyluc
Oct 10, 2008 | Televison & Video
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Can't get TV onto the AUX channel
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
