Question about RCA RT2500 System
I have the RCA RT2500 model and I am looking for directions to connect tv, DVD, gaming, Cable Box, etc are there anywhere on line I can find it? thank you
  • yelroc_niddu Jan 08, 2009
    I have the same problem. I have a cable that is white and red on one end and the same on the other. I also have a yellow one. I have a PS2 that I want to use as the DVD player. What outputs do I use.
  • 3 Answers
The back should have a squared in box around the inputs like dvd vcr sat tv cd, dvd and sat have svideo and component a/v plugs, the vcr just has component rca a/v ports, tv and cd are just for audio, then you also have the option to hook up optical for dvd and sat. just plug your vcr into the vcr box and hook up svideo or the yellow monitor out plug to your tv, hook in the speakers and turn that baby up.
Posted on Mar 26, 2009
SOURCE:
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Not able to connect my cable reciver to my rca L32HD31R
  1. Connect the RCA Output on you Cable Receiver to the RCA Input on your RCA TV, taking note of which Input you plugged into, e.x. DVD, GAME, etc.
  2. Turn on your Cable Receiver, and your TV.
  3. On your RCA TV, change the Input to the Input you plugged your Cable Receiver into.
  4. You should now be able to change channels using your cable box, and view it on your TV.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 01, 2011 | RCA L32HD31 32 in. LCD HDTV
How do i connect coax from cable box to get dolby digital surround the display will only show a analog connection
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2500-Home-Theater-Systems-manual/id/402ag605/t/2/
See page 12 and manually assign the coaxial to something other than the default CD ( SAT seems to be the closest meaning to Cable). Or just select CD and the Cable Box should come in digitally.
Feb 23, 2011 | RCA RT2500 System
I am connected to the TV from the sound system. Of my six speakers connected, I can only get sound from the SW, and the front L & R speakers. No sound is coming out of the Center or Rear L & R. ...
You don't say HOW the 'TV' audio is carried to the RT2500? TV's are usually the end of the chain, not a link in it. For multichannel audio you need a multichannel digital source. Is that the TV or would it be the cable/sat box? Try running a digital audio cable from one of those to the RCA.
Dec 27, 2010 | RCA RT2500 System
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
How can i directly connect a LG H30 TV, or a PS3 or a Wii to a Regent HT391 sound system? Is it possible to? So far the only 'surround sound' I can achieve is by connecting my tv thru the cable box...
According to the various vendors that carry this model, the unit has multiple inputs to accommodate gaming systems, dvd, tv, etc.
Look on the back of your system and see if there are inputs labeled as Game, DVD, TV, etc. You should be able to connect each component, and use the remote to switch between the multiple sources.
Good luck.
Feb 03, 2010 | Durabrand HT-3915 System
We have a cable box, rca reciever, a dvd and a non digital tv. Does the reciever need input from cable box, dvd and tv?? is red, yellow and white audio/video enough to connect or is a S-cable or optical...
From your cable box, send "optical" to the receiver. From the DVD send "coaxial digital" (looks like one rca cable" if your receiver has it, if not, optical is fine as well. There is no reason to send audio from the TV to the receiver unless you are using an "off-air antenna". If you want to have audio from the cable box to the TV for listening to TV speakers only, send an audio video cable (red/white/yellow) direct to TV. If you need more help just post a comment and I can help you some more.
Jul 07, 2009 | RCA RT2660R Receiver
What is the remote conrol code for an RCA A/V Receiver?
If you are looking for a code to program a universal remote, you probably won't find one. Universal remotes are for TV DVD VCR and Cable boxes. A replacement remote might be found at MCMelectronics or Vance Baldwin. I would guess $40-$60
Jan 14, 2009 | RCA RT2500 System
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
RCA RT2500 System Logo
169 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
