Question about Kenwood VR-309
Jvc av 35750 remote has to be very close to work
Lost original remote several years ago. have been using remotes for directv box for the last 2 years with no problems. in the last 6 months i have had to get closer and closer to get the volume and the on/off to work. the channel changer for the directv works fine. i have changed batteries and used other remotes and still the same problem. any suggestions are greatly appreiated.
    Problem Solver:
  • 17 Answers
I removed the red plastic cover from the remote sensor on the tv. behind that, i found a sticker from one of the parts inside the tv had come loose and fallen to where it was partially blocking the sensor. I removed the sticker and everything works great now.
Posted on Jan 07, 2009
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
Remote Control malfunction
Check the remote control for its infrared emission by pressing all buttons on it. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. or "How to check a remote control"
May 18, 2014 | JVC AV-32D305 32" TV
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
I lost my remote for my jvc 36" av-36020 my daughter still managed to lock the screen so all you see is a black box, we left the tv on before and it went away after a month then the power went out and...
The black screen you see is a closed captioning text box. you may be able to access the onscreeen menu from the front panel controls to shut off the captioning..If not , you may be able to obtain a universal replacement remote to access these features...If that does'nt work, then you will have to try to get an original remote
Dec 19, 2010 | JVC AV-36020 TV
Remove CC Black Box without original remote?
Hello, I was the one who assisted you in Live Chat, Just wanted to remind you to rate the chat session, Thanks. Have a great day!
Nov 25, 2008 | JVC AV-32260 32" TV
It can be done with the front panel buttons. Here's a link to the user manual from JVC's site. It's covered in the book.
http://resources.jvc.com/Resources/00/00/99/LCT0305-001B-A.pdf
Sep 24, 2008 | JVC AV-20220 TV
No Audio
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
Hope this helps.:)
Apr 01, 2008 | JVC AV-56WP30 56" Rear Projection...
Closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Aug 16, 2007 | Sanyo DS24424 24" TV
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Kenwood VR-309 Logo
87 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
