Question about Reebok RL1500 Elliptical
Intending to purchase and need to know.
Does this item require electricity?
  • 15,935 Answers
Yes the 6 panel LCD and programs it runs will require electricity.
Posted on Jan 07, 2009
Need refund for item that never came
Contact THEM, we are not THEM, we can't help you. If you tell us who THEM is, we can give you contact details. However, these details are in your confirmation email.
Jan 06, 2017 | Computers & Internet
Generator was running fine and then the electrical output quit while the engine was running.
Sounds like you did overload the capacity of the generator. What has happened is that the generator was happily running away producing the electricity required for approximately an hour and then an appliance such as an air conditioner, furnace, refrigerator, water heater, or similar large amperage draw fixture decided it was time to kick on for its cycle, or perhaps two or three of them kicked on at the same time, thereby raising the amperage requirement beyond the capability of the generator. All heavy duty appliances run at a given amperage but when they kick on for a cycle they draw almost 50 percent or more amps. Generators rated at 6000 amps or less will not power an entire home or business. When using this size of generator, disable some of your electrical items in the home by unplugging or switching off, and only connect the most important items needed for emergency use. A 3500 watt generator will only run a few lights and a television, plus only one appliance. This means that you could plug in the refrigerator and run it until it has gotten cold enough, then unplug it & connect the furnace or air conditioner or water heater so that they can do there job. Eventually you will be able to rotate through each appliance in turn, and hope the power will return soon. Your generator will likely have blown a capacitor, resistor or some similar repairable item. Some good quality generators will have an overload breaker installed, that trips before doing any damage and all that is needed is to find it and reset it, in order to continue using the generator.
Dec 05, 2013 | Campbell Hausfeld GN5060 - 5000 Watt...
I need a 125 amp GE load center cover the part number is #NP245768-3
Your best bet would be to contact GE directly - or a nearby GE Wholesale Electric Supply distributor. GE, like all electrical panel manufacturers have made many variations of panels to comply with ever-changing code requirements. If it is very old, you may need to locate a used electrical part supplier - or change the entire panel.
Sep 13, 2013 | Gb Electrical 100 Amp GE Load Center
Cleaning the fan
I use compressed air to clean out the heat sink fins and fan. This is less thorough than pulling these items and cleaning them, as that usually requires a full disassembly to access these items - but it ususally suffices if you do this on a regular basis (once every month or two).
If full disassembly is required, Google "<My laptop model> disassembly" and you will most likely find several YouTube videos or step-by-step instructions showing you the process.
One caution - NEVER vacuum the interior of a computer. Doing so can produce static electricity that can damage/destroy internal components.
Hope this helps...
Jan 03, 2013 | Computers & Internet
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
I need to know the tub size on this washing machine.
You would have to tell us the make and model for someone to be able to answer that for you ;-0)
Also you do not say whether you have already purchased the machine or intending to ;-0(
So- if already purchased have a look at the manufacturer's panel, probably on the back- it might give you an indication there- or your manual?
If not purchased go onto the manufacturer's web site DIRECT to see, OR your (intended) vendor's site?
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 22, 2011 | Washing Machines
My double electric wall oven smells like smoke, what can be the problem?
It depends o what kind of smoke. If it is just a burnt food smoke smell there is residue left on the walls that has refused to come off with cleaning and a harder detergent is required, perhaps allowed to soak for a longer time. If it is an electrical smoke smell, there is either a bad connection that is heating up and creating the smell or some wires hare carrying too great a load and are smouldering. Check the first item before looking at the next because that will require you to open the back of the oven to access the wires and contacts.
Mar 11, 2011 | GE Profile 30" Built-In Double Electric...
Hi... Intel, m very happy to purchasing Intel origional dh55tc m-board with i-3, & 2gb ram, but i want to know that, do i realy need of an graphic card?
It depends on what you're intending to use your computer for. If only for desktop applications such as word processing and e-mail, internet and basic image manipulation then you will be ok without a dedicated graphics card. However, if you are planning to play 3D games and other graphically demanding applications, then a dedicated graphics card would still be beneficial.
Oct 12, 2010 | Intel Motherboard
Reebok RL1500 Elliptical Logo
75 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
michael
michael
ray gallant
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
