Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps:
Step one: Load the item to scan
You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
Make sure that the product is connected to the computer.
Turn the product on.
Load the picture or document:
Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item.
CAUTION:
Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
Step two: Scan the item
Open HP Solution Center with one of the following methods:
Click Start , click All Programs , click the HP folder, and then click HP Solution Center
Double-click the HP Solution Center icon ( ) on your desktop.
If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
Use one of the following methods to start the scan:
For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
A screen displays to prompt for scan settings.
If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
Start the scan again.
Read through the various options for the scan settings. Make selections for at least the following items:
Scan to: Select your scan destination from the drop-down list.
File Type: Select the file type from the drop-down list.
...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
Show preview...: Select this check box if you want to see a preview before the actual scan.
Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
Click Scan .
The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings.
Using the scan button on your printer
HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer.
Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer.
To get started, click
Settings , click
Scan Settings , click
Button Settings , and then click the tab for
Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Yes scanner now working
Great! Thank you for letting me know. If you need more help. Please post your problem and fixya experts like me would be very happy to assist you.
