Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
I have an emachines computer. Its new and runs great but why does "VGA" appear with the blue plug when I first turn it on? Everything works!!!!!!!!
    Problem Solver:
  • 20 Answers
It is probably just your monitor telling you that everything is connected, Those emachines are pretty User Friendly, I can almost guarantee there is nothing wrong. Congrats on your new buy :)
Posted on Jan 07, 2009
Hello sir, I m facing a great problem with my computer. whenever I power on my computer power light remains on and all other process goes on except the hard disk light. it does not blink even it does not...
The problem is most likely with the Graphics card port on your motherboard. You will need to run the computer without a graphics card or buy a new motherboard, sorry!
Sep 22, 2013 | Sapphire Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I replaced my ram and now my monitor won't work. I took out the new ram, put the old back in and still no monitor. Everything I read mentions video card...where is that?
Being eMachines it is probably on board VGA. You can check by looking to see if the VGA lead to the monitor plugs into a VGA card or the motherboard.
Unfortunately it may be caused by static discharge when the RAM was replaced if you didn't observe anti static precautions.
Hope its a VGA board fault but if you install a VGA card and turn off the on board VGA that will work.
Hope that helps.
Dec 30, 2010 | eMachines W4685 PC Desktop
I have an Emachine model 568 part number E1573r. the monitor cable plugs into the computer but it has a wire with anther plug where does it go
Most new monitors these days have two 'plugs' for input:
The one that's 3 rows of 5 pins (usually blue) is VGA, which is the older type. (Picture here: http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/Vga-cable.jpg/750px-Vga-cable.jpg )
The more common one is a white connector, and lots of pins is called DVI. ( Picture here: http://upload.wikimedia.org/wikipedia/commons/3/37/Dvi-cable.jpg )
You can use whichever you want, but if your computer has DVI, use that, as you'll get a better quality picture. You only need one of the two to be plugged in
Dec 01, 2010 | E-Machines eMachines Monitor E15T4
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
May 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
VGA/MOTHERBOARD
yep. try disable on board card (if there is a setting) and use external video card.
Jan 08, 2008 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
