Question about Kenmore 24032\24036 Top Load Washer
Will not move to the next cycle.
Hi there and thank you for taking the time to read about the problem. The model number is 4564191 . It simply will not move the final stage of washing. I think it may be the timer from what i had read but not sure. I have a new born and need this problem solved quick. Can anyone help?
  • salon_cougar
    salon_cougar Jan 07, 2009
    This is Mike, The person that posted the problem. It moves through the cycles ( wash & rinse ) but will not move to the final stage of draining. It will just stop there after it has rinsed.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    when you say wont move on,is that rinse or spin part of the cycle
  • 33 Answers
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Jan 07, 2009
    My washer will not switch from one cycle to the next
    I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
    Jul 22, 2016 | Washing Machines
    I have a Ge washing machine that when I turn it on the mixer valves open and fill the tub. I can hear the timer moving to the next position, but it never start agitatting and then after it that cycle time...
    Sorry to read about your problem, I hope this helps you out.
    yes you can, or a defective motor.
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    Dec 25, 2010 | GE WBSR3140DW Top Load Washer
    Maytag Neptune Stackable washer/dryer will only wash one cycle at a time unless I manually move dial to next setting...also will not spin as of this morning. Model # MUE2000AYW thx
    The timer motor is bad, you can order a new one at reliableparts.com , using your model number. For information on how to perform your repair please reply and i will be happy to help.
    Thanks, Repairman45
    Dec 19, 2010 | Maytag Washing Machines
    On my Maytag Washing Machine...Sometimes my water selector works... sometimes it doesnt. Sometime hot will come out when set on cold and sometimes cold will come out when set on hot.. Sometimes it works...
    Hi and welcome to FixYa, I am Kelly. Just reading this it sounds like the water temp selector switch is acting up. You did not provide a model number so this is just an outright guess to help you. Try this if you have the button type start mashing the buttons several times between temps. Do it with conviction. Your cycling the switch to unstick or clean off the contacts in the switch. If the cycle temp switch fails while doing this; changing the switch was the next recomendation to correct the temp problem. You should cycle the switch at least 30 times methodically. Press, change temp, press repeatedly. Then check your cycle water temps for hot and cold as selected. Depending upon model you could have a problem with the water inlet valve. I will wait for a response before commenting on that.
    If you need specific model information I need your Model number.
    Thanks for choosing FixYa,
    Kelly
    Nov 14, 2010 | Washing Machines
    After the initial wash cycle, I have to manually turn knob on washer to change to each cycle when it is time to rinse and spin. What is causing this problem?????
    Hi just read your posting .I do not know the make or model number of your machine but this fault is common on timer model machine.The fault with your machine is your TIMER is faulty.To be exact it is the timer motor that is faulty.This advances the timer throe the cycles.Just a question,Does the timer move at all from the original selected position?If it does not move at all then this is the fault.Please reply with additional information on the questions and I can hopefully help you throe this problem.Looking forward to your reply.
    Jul 31, 2010 | Washing Machines
    Washer beeps at the end of each cycle,must be advanced manually
    Hi Steve just read your posting.Now when it starts to beep a series of lights will light up.Starting from left to right they are numbered 1st on the left=128 next is=64 next is=32 next is =16 next is= 8 next is = 4 next is = 2 next is = 1. So the lights are numbered from left to right 128--64--32--16-- 8-- 4--2--1. now with this information look at the lights that are lit add up the value of the lit lights and reply back and i will look in my service manual and tell you what part or parts are faulty. hope this helps.
    Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
    My Kenmore washing machine model 20602991 - the water won't stop running when filling the tub. If we catch it we can move it to the next cycle to wash, then we need to move the dial to the next cycle to...
    The timer of the washing machine is defective kindly replace the timer with proper channel please specify the model number and make of the washing machine to get the same timer
    Dec 24, 2009 | Washing Machines
    TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
    HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
    May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    Thank you for the info. washer that doesn't work
    It appears your timer has failed in this instance.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jan 08, 2009 | Washing Machines
    Lost software
    Yes, you simply go website of Manufacturer of webcam
    Enter its model number and search of driver it is totally free of cost
    > If unable to find website of Mnufacturer search driver in google
    it will provide site of manufacturer for this you put model number of webcam in for searching .
    Dec 02, 2007 | Computers & Internet
    Kenmore 24032\24036 Top Load Washer Logo
    209 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
