Question about Mitsubishi VS-6043 60" Rear Projection Television
No picture but sound red line going though the screen
I think that its either a problem with your power supply or an incredible screwed up convergence press menu if its incredibly red its probably a convergence problem. if thats the case get cheap laser eye surgery and stand really close to the tv till you can make out the first time setup menu convergence then either cancel or menu to reset it to factory defaults press the button several times for the right result
Posted on Feb 15, 2009
My R45W46 Projection TV start up with a dull red screen with some retrace scan lines on the top, sound comes up with a blast then the set goes off withthe power light remaining on.
Look to the area where the picture tubes are, especially the red on--if red screen is set too high and screen is red with trace lines it will trigger the set off as the tube is pulling too much current.
It could be the red tube itself, a issue on the red crt board or simply the red screen control needs to be turned down a bit.
Dec 17, 2012 | Zenith R45W46 45" Rear Projection...
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
No picture,but sound ok
check your ribbon connections coming from power supply board there is 2 of them it will be the second one,theses ribbions connect to signal board.Sometimes causing set not to come on.
May 11, 2008 | RCA D52W19 52" Rear Projection Television
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Eric
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
