Question about Maytag MEY12F7E Air Conditioner
Maytag ac trips at plug constantly
I wait 10 or 15 minutes and reset it but it seems to be tripping quicker now. What could the cause(s) be since it is brand new out of the box....been running all of one or two days before it started doing this......please help.
  • billy custalow May 28, 2007
    if i can't realistically replace it right now, what is the not so pretty fix option?
M3X05F2A
Posted on Jan 08, 2008
  • 883 Answers
First, get your money back or get a replacement for no charge. now, when you reset it, are you resetting the circuit breaker? if so, then first try another appliance that will demand near the same current as yours (~7-8 amps). if breaker does trip, check your house wiring. if not, then your unit's compressor motor is demanding too much current (assuming you have a 15A or 20A breaker)-not a pretty fix here. look for another unit
Posted on May 28, 2007
  • Marty marty May 29, 2007
    not pretty is costly-mostly labor to change the compressor and refill freon
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Maytag GS2126PADW fridge trips safety switch (earth leakage detector) after about 30 minutes. It's not caused by defrost heater.
The house that you live in might be using ADCI instead of GFCI. The newer protection is ARC FAULT DETECTION CIRCUIT INTERRUPTION. It can sense a SPARK and shut down the circuit.
Nov 20, 2014 | Maytag Refrigerators
My plasma tv won't turn back on after a power outage???
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
WONT RESTART AFTER SHORT TRIPS AND ENGINE HEATS TO NORMAL
If you can duplicate the event in your driveway, you can check fuel pressure and spark at the plugs when it won't start to narrow down the possible causes.
Mar 07, 2013 | 1998 Land Rover Range Rover
The Reset button on cord keeps tripping, when turned on it works for a minute then trips again
There's obviously there is a short or electrical overheating problems omewhere in the appliance that's causing the circuit breaker (Reset Button) to trip. Stop using the AC unit and have it checked by a professional.
Feb 04, 2011 | Heating & Cooling
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
Runs, but overheated, tripped outlet causing freezer full of rotten food
There was a recall on these - it depends on the age.  I bought mine in 2003 or 2004, and they sent a repairman out to replace a circuit board.  Call Maytag to see if yours was in the recall.
Aug 09, 2008 | Maytag M7DH65B2A Dehumidifier
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner constantly shuts off
Are you saying that you have plugged the aircon into an extension lead then into a socket in the wall and that the smoke was coming from the extension lead part. If so I would suggest checking all your plug in connections and chenge the extension lead. A quick way to check the compressor is a cause is to put the aircon to fan only and see if it fails to trip out the circuit breaker, then put it back onto cooling and see if it trips (if it does on cooling then its a good possibility). Most aircons have a three to five minute time delay for starting the compressor to protect against power fluctuations (ie power cuts). Hope this s of some help.
Sep 11, 2007 | Frigidaire FAC107P1A Wall/Window Air...
Maytag MEY12F7E Air Conditioner Logo
212 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
