Question about Black & Decker 14.4 Volt Battery Charger #5101181 02
14.4 volt Black & Decker Battery charger does not power up
Charger doesn't charge. Charger light does not come on.
  • hoskins May 16, 2009
    When I drop the battery in the charger, the red light doesn't come on. Nothing appears to happen. Is there a way to tell if it's just the battery or the charger?
5 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: Black & Decker 24 volt battery will not hold a
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
Posted on Mar 02, 2009
  • 205 Answers
SOURCE: Black and Decker battery charger does not work.
Open it and look for a fuse, then go buy a new one (my Ryobi charger didn't have a fuse)
Posted on Apr 02, 2009
  • 360 Answers
SOURCE: the light don't come on and want charge my 12 volt battery
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
Posted on May 20, 2009
venexcsd
  • 1185 Answers
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Posted on Jun 01, 2009
  • 20 Answers
SOURCE: My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
Posted on Aug 15, 2009
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
When I started to charge up one of my two batteries the charger light went red two seconds later it went dark and I know the battery was dead.,Then I tried my second battery which was somewhat still...
A simple volt meter would tell you if your charger was putting out or not. plus the volt meter would come in handy for many other home/auto ETC problems down the road.
Feb 03, 2012 | Black & Decker Black And Decker FS24C...
I have a B&D 24 volt drill/ flashlight/ skill saw combo, reciently either the battery or the charger is bad, I put the battery in the charger an the light on the charger flashes (even when unplugged)...
If the charger is lighting up its probably the battery. Rechargable batteries have a lifespan governed by the number of charges.
The only sure way of knowing is to have another battery or charger that you know does work.
if it is the battery its normally cheaper to buy another complete drill.
Sep 13, 2011 | Black & Decker Black And Decker FS24C...
I have a firestorm double 14.4 charger. Both lights come on but neither battery charged. The charger does not get warm.
Take a volt meter and test the connections where the battery comes in contact with charger. If you have no voltage, then the charger has failed and needs to be replaced.
Aug 25, 2011 | Black & Decker Black And Decker 12 Volt...
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
The light don't come on and want charge my 12 volt battery
May 20, 2009 | Black & Decker Black And Decker 12 Volt...
Black & Decker 14.4 Volt Battery Charger #5101181 02 Logo
795 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Phil Rivera
Pieter Vleeshouwers
john h
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
