Question about Samsung SF-3100 Plain Paper Inkjet Fax
Samsung fax parts
Our fax machine was sent in for repairs because the paper does not feed through the scanner?s (sending) side. We received it back a couple of weeks later unfixed. We were told that the whole chassis had to be replaced because a small plastic clip broke off. (Reason being people pulling paper out when machine feeds more than one page, which made the gears go backwards) We asked the technician to show us how & where this part is so that we can glue it ourselves. To no avail. It is at the roller on the right. Please be so kind as to assist in this matter as they want their loan fax back & we need a working fax asap. Thanking you with regards C Klopper Thatch-it cc (012) 991-3500
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
THE ONLY SOLUTION IS TO CUT A U SHAPED PART AND FIX IT USING SUPER GLUE AND FIX THE WHITE ROLLER ON./ OR REPLACE THE WHOLE CHASSY HAPPY FAXING OMNIPRESENT
Posted on Sep 23, 2007
Can't send fax, can only receive
you can't send the fax, the paper don't feed, you need to clean the paper path the roller that guide the paper to pass under the the scanner must be cleaned with alcohol. you need to unplug the fax from the power source. after cleaning wait for 10mn and try to send a fax.
Dec 23, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
We can receive but won't take the paper to send a fax out
You have an ADF paper feed problem, try taking some rubbing alchoial and clean the ADF paper feed tires, This helps the paper to feed into the scanner unit so the fax can be sent. I have also seen part of the ADF feed unit broken.
Does the paper feed in but not transmitt out?
Aug 28, 2008 | Sharp Office Equipment & Supplies
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Samsung SF-3100T parts
Hi there the thing is if you were to glue this back into place the likely hood is that the machine will not hold as there is a quite a bit of pressure within that area. The best option is to obtain a new machine as trying to fix will out way the cost of the machine.
Thanks J
(Sorry cannot help anymore)
May 28, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
Samsung SF-3100 Plain Paper Inkjet Fax Logo
77 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
