Question about Toshiba 42H81 42" Rear Projection Television
Sound is muffled toshiba 57h81
Mute is off but sound is muffled even when volume is set to the max.
There is a switch at the back of the set for audio, it is in the wrong position.
Posted on Jan 07, 2009
Problem with radio, volume on max but sounds all muffled
Check speaker connections.at speakers, and if necessary, on back of radio.
Jun 11, 2012 | 2004 Jaguar X-Type
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Have a toshiba 42H83 how do I get into service mode? think it is menu menu(hold) and push what at the same time
ENTERING TO SERVICE MODE
1) Press MUTE button twice
on Remote Control.
2) Press MUTE button
again to keep pressing.
3) While pressing the MUTE button,
press MENU button on TV set.
May 16, 2010 | Toshiba 57H81 57" Rear Projection...
No Sound on Toshiba 57H81 projection TV. Picture is fine.
The sound amplifier IC has went bad and needs replaced. Call a good TV Tech.
Check with the BBB 1st before you decide on one.
Jun 19, 2009 | Toshiba 57H81 57" Rear Projection...
Garmin nuvi won't talk
Go to Tools|Settings|Language|and change it to "American English (Jack or Jill) TTS).
Jun 13, 2009 | Garmin Nuvi 660 GPS Receiver
My Toshiba Satellite has a sounds problem
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
SOND FAILURE
open the sound device window in xp..by clicking on .... start/control panel/sound ,speech and audio devices/sounds and audio devices/......make sure firstly in the volume tab that vol is not set to mute or at a very low level ( i usually set it at max of 7) then click on advanced box and once again make sure none of the settings are set to mute. or very low ..you can fine tune these settings later if you wish...if you click on the advanced box within the far left master volume area then have the tick on in the s/pdif box....see hoe this goes and let me know
Jan 04, 2008 | Toshiba Satellite A105 Notebook
Toshiba 42H81 42" Rear Projection Television Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
