Question about Dishwashers
Dish washer will not drain
We have a Quiet Power 3 by GE, The dishes come out clean but the water will not drain out at all....I've alredy have taken everything apart and there is no problem with my sink or garbage disposal. What can I do to solve this issue?
  • 33 Answers
Repairclinic.com
Posted on Jan 07, 2009
What I did was replace the 'magic drain' on the sink- u know the back flow value that drains to the disposal. solved it-
Dish washer not draining
May be that there was a little regular soap or something put in that made it suds up. vegetable oil poured into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 11, 2009 | GE Dishwashers
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Water backs up to the dish washer from the sink .
Check the drain hose under the sink. It should have a high loop an upside down "u" like a hill the water can't climb to get from the sink to the dishwasher. That is where I'd start. Good luck.
Jan 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Drain Clogged
you might try pouring liquid plummer in the drain part and jet it set it shouold eat through whatever is in there
Dec 26, 2008 | Dishwashers
WATER WILL NOT DRAIN HOW MANY YEARS WARRANTY DO I HAVE??
it has a drain pump that pumps the water out when time to drain / replace it it should fix the problem
part number is WD26X10016
Dec 12, 2008 | GE 24 in. Profile PDW7800 Built-in...
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Almost new GE quiet speed 2 dishwasher not working properly
look at the spray arms see if they are stopped up look at the little holes in it hot water cleans dishes always make sure you get the water as hot as you can stand it before starting the washer as new washer dont use as much water as older ones so you can fill it with cold water before hot gets to the sink
Mar 31, 2008 | Dishwashers
I have a GE Quietpower 3 dishwasher and let me tell you it is the worst dishwasher, hands down that I have ever owned. It is not quiet and it certainly does not have any power to clean anything. Or so i thought. After reading a few of the posts on this site it dawned on me to check the drainage. I took the whole drain assembly apart. Cleaned all of the gunk out of it. Then went for the drain hose. It was just about a clean as it was brand new. Then i reexamined the drain and found that it did not drain into the Garbage disposal like I am use too. Instead it had to make an immediate 30" climb into a PVC drain that sat just below the underside of the countertop. I rerouted the hose to dump into a bucket and ran the dishwasher. Guess what??? All clean and no residue. I am off to Lowes now to get the clamps and such to drain the dishwasher into the disposal. I still think this dishwasher is the worst I have ever owned and think GE should give that Six Sigma save a few pennies on one DW and the company can save hundred of thousands, at the expense of a customer spending hours on fix-it sites to find out the company cheapened the pump, a rest! However, for all of you that just want to fix your dishwasher, try draining it into the Disposal now before you blow your pump out.
Mar 08, 2008 | Dishwashers
Dishwashers Logo
271 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
