Question about HP PhotoSmart 7660 InkJet Printer
Hp photo printer 7660 paper size error
I can print fine using fast draft, fast normal, and all other print qualities except for normal.
I have uninstalled and reinstalled the drivers and rebooted.
still no change.
what could be wrong?
  • 66 Answers
It is a correct driver of your printer? if so try to reinstall also your OS maybe is attack by some worms.
Posted on Jan 07, 2009
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
Hp photosmart 7760 the prints will not dry
hi
goto the cntrol panel--->printers and faxes--->right click the printer icon
click on the printing preferences and check the print quality ,try to set it to fast draft...this should save the ink as well as dry it faster.
hope this works
Jul 14, 2009 | Office Equipment & Supplies
Blurred officejet 4620 photo
Have you checked to be sure that -
  • you've designated the paper type as one of the photo type papers?
  • you've designated the print quality as either Normal or Best (NOT Draft or Quick or similar low-quality print)?
  • you're using one of the photo-type papers?
  • none of the ink cartridges is low on ink?
Sep 17, 2012 | HP Officejet 4620 All in One - CZ152AB1H
I cannot get an E-size plot to print properly. I have no trouble with plotting D-size drawings. What are the correct settings to use to print E-size sheets?
Printing high quality photos using an inkjet printer is not only possible, but affordable too. Top notch quality relies on a few factors: the right paper, the right ink and the right settings. Read on to find out how to print photos with an inkjet printer.
1.Use a good digital camera. For 4x6 and 8x10 prints, you will want a camera with at least two or three megapixels.
2.Buy photo paper. Spend the extra few dollars to get high-gloss photo paper that is designed for your printer.
3.Use photo ink. High quality photos take high quality ink. Do not use the same ink that you use for documents.
4.Optimize your settings. Select "File > Print" then click "Properties" and find the preferences or quality tab. Set the quality to the highest or choose a photo preset.
5.Edit photos on your computer. Import your photos from a CD or your digital camera. See your camera's manual to find out how.
6.Crop and resize. Cut out anything extra in the background that you do not want and resize the picture so it will fit on the page.
Sep 19, 2011 | Canon iPF700 InkJet Printer
Photosmart 7660 has 4x6 photo paper in it but it is not loading and out of paper keeps coming on.
Have you loaded paper on correct side or it will not detect the paper. Ensure you have also selected the paper size in the print options menu.
Mar 05, 2010 | HP PhotoSmart 7660 InkJet Printer
It takes a long time to print simple one line word doc
At the settings properties of your printer there is the abbility to change the mode of printing. Like High resolution, Normal, Normal Fast, Draft printing. Change to Normal fast or draft and your document will be printed in seconds!
Oct 27, 2009 | HP PhotoSmart 7660 InkJet Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
How do you print from dark to darker using HP officejet 5610 printer ? When I am photo copying, the result of a copy, is hard to be read.
there is a setting on the control panel for "Best Normal or fast"select best for high quality, Normal for normal and fast for draft copies.
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP PhotoSmart 7660 InkJet Printer Logo
87 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
