Question about SanDisk Sansa e260 MP3 Player
My MP3 player keeps restarting when I turn it on. I tried reformatting it, I've tried the recovery mode everything but it won't get past the SanDisk screen, it just keeps restarting. Please help!!!!
  • 3 more comments
  • Norman Rebadow May 28, 2007
    I dont see a pin hole anywhere?
  • Norman Rebadow Jun 04, 2007
    No, I contacted SanDisk and returned it to them. They are sending me a replacement.
    Thanks for your help!
  • Anonymous Feb 10, 2008
    it just at sandick mue
  • Anonymous Apr 05, 2009
    My SanDisk Sansa e260 MP3 Player keeps restarting when ever i on it and i dont know why it keeps doing that
  • ncat27 Apr 05, 2009
    i plugged it into my computer and it went right to the sandisk intro screen.
    it keeps flashing there non stop.
    i tried to reformat but i can't find the original format disk that came with it.
I just formatted it: right click the drive and select format: "full format.
The drive can be found in My Computer, after you plug it in. it's named "Phillips"
Posted on Sep 21, 2008
I still have this same problem but only thing is that i've had mine for over 4 months now so i don't think sandisk will give me a new one
Posted on Jan 25, 2008
  • 883 Answers
Look for a small pinhole to reset the device
Posted on May 28, 2007
  • Marty marty Jun 04, 2007
    then hold down the start button for a long time, like 15 seconds, then release it. then start normally, any change?
HELP
Reformat the player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 13, 2008 | SanDisk Sansa e250 MP3 Player
Now it says "Load main image failed Switch to Recovery mode"
It means you have to reformat your player
-Tha Mp3 Doctor
Aug 12, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 2gb mp3 player
-Tha Mp3 Doctor
Jul 21, 2008 | SanDisk Sansa e250 MP3 Player
Frozen sandisk sansa clip
Restart the computer once and try replugging the player again. If it is still a no-go, I would just double-check everything. My Sansa Clip had the same problem after working fine for a couple of months. I reset the player, which solves the freezing issue one time, but doesn't correct it permanently. I did the firmware upgrade and the Sansa Recovery Tool. Then, the computer didn't even recognize that the player was plugged in. So, I used the volume +/recovery method - disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. I even reformatted the player inside of Windows Media Player. Nothing. I was just about to give up. Then, I restarted the computer, and the player started working as normal. I think that the Sansa Recovery tool, in particular, requires a computer restart for it to initiate correctly.
Jun 01, 2008 | SanDisk Audio Players & Recorders
Creative zen recovery mode
I tell you how to go into recovery mode, but taking apart the mp3 player may have caused ireeparable harm.
-Tha Mp3 Doctor
May 28, 2008 | Creative Labs ZEN SLEEK MP3 Player
Reformatting Mp3
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 23, 2008 | Nextar MA566 MP3 Player
Recovery mode..?
Use the volume + method listed below:
-Tha Mp3 Doctor
May 20, 2008 | SanDisk Sansa e250 MP3 Player
Still Stuck in Recovery Mode.
Recovery mode:
Feb 17, 2008 | Creative Labs ZEN V Plus MP3 Player
Restart
try doing this and let me know if it goes into recovery mode
1. with mp3 off slide the hold button to on so it locks
2.hold down record button on left hand side and keep held down
3. whilst holding record turn mp3 on still hold down record it should now be in recovery mode if your mp3 player gets this far then it can be fixed.
Once in recovery mode goto sandisk site and you need to goto downloads and download latest firmware for your make and model once downloaded it will talk you through how to istall this onto your mp3 player if you have any problems let me know ok
Feb 11, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e260- messed up
Download latest version of Quicktime
Oct 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
