Question about Intertherm P3RA-048K Air Conditioner
Not heating I have a Intertherm. the heater does not turn on, I can get the fan and every thing to turn on but not the heating coil. the heating coil starts but then shuts off before the fan kicks on.
    Problem Solver:
  • 14 Answers
1st you said the fan runs..but partial info so best guess it fan limit contor bad.
Posted on Jan 10, 2009
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Is the heating coil on my furnace supposed to come on before the fan or visa-versa?
Heating coil comes on first. When heat gets to a specific level, fan comes on. Fan stays on after coil is de-energized until heat drops back to that same specific temperature.
Charlie
Feb 20, 2011 | Intertherm Heating & Cooling
Heater fan runs manual/ not auto
The heater fan kicks -in by a heat relay and when it reach the correct temp. it closes and starts the fan. Locate this and jumper this to see if the fan kicks in!
Dec 18, 2009 | Intertherm Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
The fan runs continuously, with thermostat set to
When was the last time you had the coils in the condenser cleaned. Dirty coils can insulate the refrigerant tubes, causing the fan to constantly run in order to try and cool down the refrigerant returning from the evaporator coils(a-coils) in supply ducting, But can.t because the condenser coils are insulated not allowing the heat to escape. I would try this first before replacing expensive parts. It is the small things that we overlook that is most likely the source
Aug 22, 2009 | Intertherm P3RA-048K Air Conditioner
Blower will not come on
could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
Jan 04, 2009 | Kitchen Appliances - Others
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
77 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
