Question about Asko 1595 Dishwasher
Asko dishwasher problem
When I turn my Asko dishwasher cycle on, the dishwasher fills with water and then stops completely about a minute later. All of the red lights appear as if the cycle were done, but it hasn't even released the dishwashing liquid yet. The dishwasher worked fine for a few weeks after I had it installed. I don't know what happened.
  • jay2021 Feb 10, 2009
    Ours will run for a while and stop..the only way to shut it off is to shut the power off but it will not continue through the cycle or complete the wash...the coffee cup light and one other light keeps blinking and the dishwasher motor hums like it is on but will not go to the next cycle.
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
Posted on May 29, 2007
SOURCE:
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Sep 02, 2010 | Asko 1375 Dishwasher
Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Oct 09, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
1,308 people viewed this question
Top Asko Dishwashers Experts
Jose Pino
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
