Question about Kenmore 14410 Humidifier
Hi, I lost the directions for my kenmoore table top humidifier model 437.14102. is tap water ok or do I need to use distilled water? thanks
  • 8,197 Answers
Tap water is fine to use.
Good Luck And Please Rate FixYa!
Posted on Jan 07, 2009
My humidifier is spitting water plus steam. Kind of weird. Didnt do before. Level of water is ok, added 1 flat tablespoon of sea salt and 2 tabkespoons of vick oil. What's happening?
More than likely, mineral scale has built up inside the tank and the mist tubing.
To clean it, turn the unit OFF & unplug it. Empty any remaining solution that's in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Plug the unit in and turn it ON. Allow it to run for 5 minutes, then turn unit OFF and allow it to soak for 30 minutes to and hour.
Then turn the unit back ON. If the water spitting has stopped, run the unit unit is half empty. Turn it OFF, unplug it and empty any of the remaining solution. Refill with Bottled Distilled Water and run it until it's empty. Doing so, will flush out any of the remaining solution and scale.
In the future, it is best to use Bottled Distilled Water, rather than tap water. As the Distilled Water does not contain any harmful minerals or chemicals.
Hope this helped you and thanks for choosing FixYa.
Sep 15, 2011 | Vicks V150SG 1 Gallon Humidifier
Can I use distilled water in my Sunbeam ultrasonic sul496?
You most definitely can. In fact it's better than using tap water. As it doesn't have all the minerals and chemicals that tap water has, that cause scaling.
Thanks for choosing FixYa.
Sep 09, 2011 | Sunbeam Ultrasonic Humidifier
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
Hi have a vicks warm steam vaporizer model v188. works great, just wanting to clean it. Can't find my manual anywhere.
The easiest ans simplest way to clean it, is too mix a 50/50 solution of White Vinegar & Bottled Distilled Water (enough to fill the tank) and fill the the tank with the solution. Allow it to set for 30 minutes, then turn the unit ON. Allow it to run, until the tank is half empty. Pour out the remaining solution and fill with the Bottled Distilled Water Turn the unit ON and run until the tank is almost empty. Following these instruction will remove all the lime and calcium build up in the unit.
Tip: Using bottled Distilled Water rather than Tap Water, will totally eliminate calcium and lime buildup.
I hope this helped you and thanks for choosing FixYa.
Aug 13, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Model V5100NS - Nebulizer has heavy deposits from water. Attempts at cleaaning (with vinegar) has caused black coating to be removed, revealing rougher, gray surface below.
mbethlinn, it sounds like you have more than water deposit issues. Not sure had you tried to clean the unit with vinegar, but if you didn't dilute it (50/50 White Distilled Vinegar and Bottled Distilled Water) and you used your tap water, that wasn't really going to solve the problem. As you tap water has a lot of minerals in it to start with.. I suspect, it's well water and there my be a problem with the water pipes in your home (i.e. Galvanized pipes) . Which over time deteriorate from the inside out and contaminate the water. That's why they haven't been allowed in almost 20 years in new home construction. Or there may be just a short section of Galvanized pipe, somewhere in your water piping system.
In any event, at this point the best solution is to use the mixture I mentioned above and allow it to soak overnight. Then flush it with Bottled Distilled Water. In the future, knowing what you already know about your water supply, you would be better served to always use Bottled Distilled Water in your humidifier, rather than tap water.
Hope this helps to solve your problem.
May 20, 2011 | Vicks Ultrasonic V5100 Humidifier
Hello! I have a 33201 Hunter Humidifier and for some reason does not run. It turns on (light comes on) and I can hear a faint hum if I put my ear to the unit... but again it does not come on. It does...
Hi, Mark! It may be clogged with a calcium scale build up from the tap water you use. Unplug the unit and empty any water that is the tank.Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water. Mix enough to fill the tank. Let it soak for 2 to 3 hours and turn the unit ON. If it starts functioning as it should, allow it to run until the tank is 3/4's empty. If it doesn't operate as it should, allow it to soak overnight. And try again, following the procedure above. After it has run to the 3/4 empty point, turn the unit OFF. unplug it and dump the remaining solution. Refill the tank with Bottled Distilled Water and run again, for at least 2 hours. This with flush the system of the vinegar and water solution.
To avoid having this problem again, always use Bottled Distilled Water, rather than tap water.
Hope this helps to solve the problem. Have a Happy Easter!
Apr 22, 2011 | Hunter 33201 Humidifier
How do I clean this humidifer? I have the sesame street elmo and friends cool mist humidifier and I cannot find the manual for cleaning instructions. thank you
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
Apr 19, 2011 | Kaz Sesame Street Elmo & Friends...
How do I clean it?
If you're asking how to clean the inner workings of the humidifier ... Run a 50/50 solution of White Vinegar and Water through it. Then flush it with Bottled Distilled Water. As a matter of fact, using Bottled Distilled Water all the time, will cut down on having to clean the unit as often. Distilled water has no minerals and will not produce scale, like tap water.
Mar 10, 2011 | Slant Fin Cool Mist GF-220 Humidifier
Water for humidifier
Distilled or bottled is best. I will help prevent build up internally. Steve
Dec 13, 2008 | Hunter Humidifiers
Produces a ton of white dust... Why???
Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
Feb 29, 2008 | Vicks V5100N Humidifier
Kenmore 14410 Humidifier Logo
87 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
