The oven on our Siemens xTronic HG2415uc will not come on. All the burns in top work fine, just the oven is having troubles. I have tried bake, broil, and convection. When you set the temp and press 'start' you hear a single click, but you never hear the gas light. Also, I have waited 10 minutes or more. One good thing is there is no gas odor. I also tryied unplugging the AC power to see if a reset might fix it, but to no avail.
Thanks in advance
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine,
fan works fine, but the oven will not heat regardless of the mode
(broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
SOURCE: Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
SOURCE: seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
SOURCE: top oven not heating up on BAKE, broiler gas and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
heatman101
Same problem too. But the cleaning phase does work. So it obviously ignites.
I have the same problem with my xTronic, however my broiler does work.
Dave
try the ignition device
repairclinic.com or simmilar site ,,,you need make. model # and serial #
