Question about Kenmore 22422 Top Load Washer
Kenmore 70 series
How do i remove the pump from the front of the motor i have replaced the coupler put it all back 2 gether and the pump started leaking under the bottom clip got the pump and motor back off dont wanna break it any more please help
  • 5,911 Answers
The following link explains how to replace a pump on a Kenmore top loader:
http://www.fixya.com/support/r397092-replacing_water_pump
The pump is only held in place by two retaining clips. Once the clips are removed, the pump (with hoses still attached) pulls directly off the motor shaft. NOTE: If the pump is leaking, it is NOT repairable and requires replacement. These pumps are sealed units. Replacements can be ordered on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offere competitive pricing so shop all three for the best price. If you require addtional assistance, please let me know. I hope this helps you.
Posted on Jan 09, 2009
Kenmore Model 110.20702990 (top loader Series 70). Machine fills with water, cycle timer(s) seem to be working ok, motor seems to be working and the water pumps out after the wash and rinse cycle. ...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702990/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Jan 05, 2011 | Kenmore Washing Machines
I have an older, but in good condition, Kenmorre 80 series top loader washing machine. The spinning won't move or when it starts washing, the arm in the middle doesn't spin the clothes around. Would it...
The Sears series numbers (70, 80, 90) only mean how many "bells and whistles" a washer has. The most important thing is the full model number. Usually a number starting with 110.########.
Most models don't use belts anymore but use a Motor coupler.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.######) and you'll see a list of major sub-components with diagrams and parts.
damaged.
Nov 21, 2010 | Kenmore Washing Machines
Our Kenmore 70 Series washer is not spinning or agitating. From what I've read, it sounds like the coupler, but we can't figure out how to take the back of the washing machine off to put in the...
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Aug 10, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore Model 110-22702 series 70 top loading washing machine. The agitator barely turns and it wont spin. it fills and drains but tub won't spin, i can hear the motor running like it wants to...
May 07, 2010 | Kenmore Washing Machines
Model 22748 kenmore 70 series washer. fills but
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92274800&pathTaken=partSearch
It is also likely the source of the burning smell.
(Sears price $18.86 but available from most appliance repair shops)
Apr 22, 2010 | Kenmore Washing Machines
Kenmore 70 series washing machine that has a terrible smokey smell. Now my clothes have that horrible smell. What could the problem be and is it worth fixing.
Top load direct drive whirlpool / kenmore washers use a Motor Coupler between the motor and transmission.
The coupler consists of two plastic pieces with a rubber piece between them.
If the plastic pieces are broken, you may be smelling the rubber piece "burning"
Following is a description of how to access the coupler and check it.
It's a relatively inexpensive piece and is designed as a fail safe between the motor and transmission.
It's very easy to replace if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Nov 25, 2009 | Kenmore Washing Machines
Kenmore series 70 washer fills and drains, but agitator is really slow and with noticeably louder humming noise. whats wrong with it?
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
Oct 09, 2009 | Kenmore Washing Machines
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Jun 08, 2008 | Kenmore 24032\24036 Top Load Washer
Belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
183 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
