Question about LG DLE5977 Electric Dryer
Need to replace existing back vent to side vent. Is there a kit
See above
  • skingston Jan 08, 2009
    Thanks for the info, I'll definitely check this out.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
From underneath the machine you can install a side venting kit. It can be vented to either side on electric models. Part number is 3911EZ913X. You can order parts by calling LG at 888-393-6484. Hope this helps.
Posted on Jan 07, 2009
What product can I use to replace a down draft venting system from a Jenair range when I have to install a range hood above a new range and wish to vent down and out of my house in the same place of the...
Short answer is if you have the vents already in there is a product to make use of these. I would recommend talking to an appliance dealer for your options on this one. I am sure they would steer you in the right direction.
Mar 01, 2015 | Range Kleen For Whirlpool Jenair Ranges
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
How do you change the dryer vent on a Kenmore 800 series
yes and here is the part kit that you need..part # 279818..onthejob..everthing you need is in this kit..it all comes together..
Jan 12, 2009 | Kenmore 63942 Dryer
Water in vent
your vent out the house is broke or fell off,,suspose to a flap or lilltle blind type,,the cold air is coming in whule the hot air is trying to get out and it condensates in the vent hose ,,replace out side vent..with new vent kit..the best by is window ehaust kit...onthejob
Jan 10, 2009 | Kenmore 82822 Electric Dryer
Maytag Dryer
You can order a side vent kit for it or make one yourself. The kit has a couple of extensions and an elbow that will turn the exhaust out the knock out on the side. You can pick up everything you need at the hardware store but the kit has precut pieces and installation instructions. If it is not a big inconvienience to wait for it, I would recommend you order the kit through a maytag dealer or sears. That way you have the right pieces and instructions to follow.
Oct 21, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
LG DLE5977 Electric Dryer Logo
1,095 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
