Question about LG MZ-42PZ14 42 in. Plasma Television
Red Spots on 42" LG plasma t.v.
Whenever the screen is dark, hundreds of red spots "dancing around" on the screen can be seen. Any ideas what may cause this? I appreciate any helpthat you may be able to provide.
  • 13 more comments
  • dsdaniel Nov 23, 2007
    I have the same problem with LG plasma.
  • Anonymous Nov 29, 2007
    We have same issue with Toshiba 42" plasma. Does not occur or is not visible during regular viewing however.
  • BZRigger Nov 30, 2007
    I have the same problem with a 42" Hitachi plasma. It's not visible when the screen is bright, however it is very noticeable when the screen is black.
  • Kendaman Dec 13, 2007
    Me too 42" Toshiba
  • Anonymous Dec 30, 2007
    Same problem here with a 50" LG Plasma. Exact same problem.
  • Stew72 Mar 21, 2008
    I have the same with my 42 inch Hitachi plamsa, but I have noticed that this only appears after 30 minutes to one hour, I think when the TV gets hot.
  • DMRdawnr May 14, 2008
    Same problem with Phillips 52" plasma with Ambilight
  • Anonymous Jun 23, 2008
    same exact problem with my philips ambilite
  • Anonymous Aug 07, 2008
    Samething dark screen dancing red spots.
  • daviddarby Aug 11, 2008
    Same problem with my LG 42 ince plasma TV. Dancing red and green spots when the screen is dark.
  • carlgina Oct 07, 2008
    I have an Hitachi 42 inch sd Plasma. After a year of owning it, the red and green jumping spots started to appear on my left side of the screen it has become worse over time and it is really anoying to watch,In order to make it less appearing i have to have my brightness and contrast set to the highest setting..
  • Anonymous Oct 08, 2008
    I have actually tried, using every input including Component and AV and I still have the same problem, I have tried to take away all other cables and untangle the ones left and nothing works. I still think it has something to do with the unit getting hot, as it only happens after it has been turned on for about 30 minutes.
  • debsnpete Oct 08, 2008
    same problem here,but it isnt connected to anything HD so not sure if the HDMI input is our problem.
  • Anonymous Jan 02, 2009
    Red and green spots whenever the screen is dark
  • dlukenda Jan 04, 2009
    I have a LG Plasma 42PC1D with the same red spot problems. I called LG and they dont stand by their products after one year. My only solution is to never by LG again.
    PS. Remember the old crappy TV brand called Goldstar? I guess LG didn't like their old name either.
The dancing spots can be sorted by you taking the back panel off and adjusting the va and vs adjusting nobs , you will need a multimeter so you you can adjust the voltage to the right settings that are on a sticker on the back of the panel. You must remember to connect the black pointer to the earthed wire to get and the red to the live wire that has va or vs at the end of it. The right voltage measurements will be be found on a sticker at the back of the panel.
I advise you not to touch the setup and setdn nobs as these are factory settings and should not be touched.
If the va and vs do not sought the problem then try the vy and vsc adjusting nobs but only touch those if the va and vs does not fix your problem first.
Once you have done everything right your tv should be better then before with clearer pictures.
I hope this helps and be careful not to get zapped.
Posted on Dec 13, 2008
  • chris kelm Feb 17, 2013
    were are the va vs on the back pannel
Had red snow on my 22" LCD and the problem ended up being a cable which wasnt fully inserted.
red spots disappeared the moment i pushed the cable in fully
Posted on Oct 20, 2008
Red and green snow in lower center of 50 inch plasma magnavox have to have contrast almost all the way down to minimise problem so tv cant be as bright as i would perfer but if contrast is all the way up, their will be blue dots along with the red and green- if somebody knows how to fix or diagnose problem please post-
Posted on Oct 07, 2008
This is a partial solution because it did not completely get rid of my "red snow". However, it did minimize it.
I installed a three phase power conditioner for all of my AV equipment and was amazed at how much it helped. I do now think the problem is an interference problem, unfortunately, I also think that the HDMI input on my set is picking it up, not any of my cables.
If anyone else tries this and it helps, please post here.
Posted on Jan 08, 2008
  • BZRigger Oct 07, 2008
    Seems a lot of people with plasmas have this problem. I can tell everyone one thing, it's not the power supply board. Mine went out and I had it replaced. I had hoped it would fix the problem with the red sparkles, but it did not. Problem remains exactly the same. I still suspect the HDMI input, since I don't have the problem on any other inputs (component and standard AV).
Could it be static from the many twisted and coiled lines running to the tv,reciever,etc?
I have Lg 50pc3d-ud and it has very dark spots on the tv that moves around. The screen is also very dark no matter the settings. The dark spots aren't always there, they go away sometimes but if...
This problems ur tv are having only can be two causes 1) The Y-Sustance main tuner logic board or 2)The tv Plasma screen panel itself it is slowly leaking radiaton and dying,if it is the tv plasma screen panel itself it is dying than the tv not worth repairing because by replacing the plasma screen panel itself will cost the same as a new tv itself.The Y-Sustance board-that the tuner main logic board that take in the tv incomming broadcasting signal cable.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish Y-Sustance main tuner logic board for replacement.This tv problems are 50/50 between the Y-Sustance main tuner logic board or the very exspensive plasma screen panel itself.
Oct 27, 2011 | LG 50PC3D 50 in. Plasma Television
I have poor color and when the screen is dark many red green yellow dots dancing all over on my LG 42 PX5D
This is a common fault on all LG sets with few people offering any solutions. I can offer a solution that could remove 95% if not 100% of the dots.
Remove the back of the set, there are about 40 screws. On the left hand side on a circuit board you will see 3 or 4 blue plastic boxes with yellow screw adjusters in them. The only 2 you are interested in are VR3 "setup" and VR2 "setdn". Mark the location with a marker pen so that you know where the factory settings were. Then turn VR3 fully clockwise. If this does not get rid completely do the same with VR2. This worked for me today, I was about to throw the TV away but I now have a 95% improved screen, sharper and more vibrant picture and saved hundreds. Hope it works.
Dec 23, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a LG42PG20 plasma tv that the sound works, but the tv has no picture. The screen is blank, dark in color.
cleanning inside,,,,check the red wire that to the screen inside moved it around,,,,plug in,,,try on...works....or not.so on..broken....not around shocks
Aug 27, 2010 | LG 42PG20 42 in. Plasma HDTV
I have a LG plasma 42PC1D (4 years old). For the
I had the same problem a few months after buying the TV, called LG and they sent a tech to replace two boards in the tv. No further problems since.
Dec 21, 2009 | LG 42PC3D 42 in. Plasma Television
What is the manufacturers warranty on my lg 42px3rv as i have lots of red and green spots on the dark colours,sometimes this is worse than others
The manufactures warranty on these sets are 1 year labor 1 year parts.
I hope this helps.
Your feedback is greatly appreciated.
asnowman
Aug 01, 2009 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Dell W3000 display issue - band of red dots on the left side
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
Touch of snow on my screen
google software upgrades and try. if not look at Z-Sustain or maybe Y-Sus
Dec 03, 2017 | LG 42PC3D 42 in. Plasma Television
LG 42" Plasma Red Spots/Mist on moving Black images
I was told this was a ramp voltage setting and any tv engineer can fix it quickly.
Feb 08, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sony Plasma 42 fwd-42pv1 interference / spots
thats a defective light engine..............new tv buddy..............its a known sony problem..........dont listen to thier b.s.
Dec 18, 2007 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Lg 42" plasma
This may be in part with the X - Y addressing to the screen. The fault can be a bad ribbon cable, or a failed drive board. On rare occasions it can be the screen itself.
Proper troubleshooting would be required to actualy determine the exact fault.
The cost will not be cheap for this type of fault. For some of these types of faults, the cost can be more than a few hundred dollars to start.
Jerry G.
Dec 01, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
LG MZ-42PZ14 42 in. Plasma Television Logo
8,313 people viewed this question
Steve Allison
Steve Allison
