Question about Hamilton Beach Water Cooler with Storage Cabinet
How to clean/repair water cooler
I have a Hamilton Beach water cooler and it stopped heating the water a while back. Now the cold water side is coming out really slowly and the water tastes funny.
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
Posted on Dec 20, 2009
I own a Greenway Water Cooler...it has not been used for about 2ys....When we went to use again it no longer dispenses water...What can be done to make the water work again?it has Ice around the top where the bottle is loaded. Please advise...
CPA848
Posted on Oct 05, 2009
It could just be that the fuse is out. The fuse may be located on the outside back of your water dispenser or you may have to open it and find it.
Posted on Jun 29, 2009
  • 286 Answers
For water cooler/heaters:
If it's not warming the water there is likely a bad thermal fuse or temperature sensor. It needs to be repaired.
If it's not cooling, you could have a bad compressor, a bad temperature sensor or a bad thermal pad (depending on if the unit uses a thermal pad or a compressor). Don't purchase stuff like this from Craig's List because you will end up with junk that doesn't work.
For taste/smell: Read the freaking instructions for gods sake. Clean the cooler with vinegar and water (just like any other water heating or cooling product including coffee makers). I can't believe how helpless people are.
BTW, for those people who obviously can't read instructions, you don'
t tag your question onto other people's questions, you create a new question. All you people who entered a question in the SOLUTION window are idiots. A question entered as a solution will not even show up as a new question and will likely never get answered. Lucky I was here looking for something else. I know it doesn't help that this site is confusing and hard to understand, but really if you read the instructions it's not that hard to use.
Posted on Dec 28, 2011
  • debraddeerin
    debraddeerin Nov 09, 2012
    O it must be niceto be perfect! You are a real ******* Mergatroid hemorrhoid
  • Anonymous Aug 19, 2016
    wow...why help if you are so critical and unkind???
Hi we have water cooler, we just re-fill water up, and used water to drink. we has it for a year, and the fuse cut the electrical out in house, what problem do i have to find it out?
Posted on May 31, 2012
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Feb 23, 2010 | Hamilton Beach Water Cooler with Storage...
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler Model 2202 cold water does not get cold. How can I fix the problem
No Cold Water
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
Aug 15, 2009 | Hamilton Beach Water Cooler with Storage...
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton beach water coller
hello chattie wm,
Welcome
You said, the hot water side stop working,no hot water
This is usually one of five things.
  1. Check that the power is on at the breaker and the cooler has the proper light lit up that shows you it is on.
  2. If you have had it a while, (year or more) it may be that the heating element is covered
with minerals from the water which if it's hard water can happen too!
3.The heating element may be bad and need to be replaced.
4.The thermostat may be bad.
a.How old is it ?
b. What did it cost to buy?
You do not want to spend more than half what you payed for it to repair it!
Let me know how it goes and what you decide.
Thank you for using fixya,
Huum....Please remember to leave a rating!
Oct 14, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
No Cold Water
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing.
May 27, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
8,144 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
