Dell dimension cpu unit on button flashing orange and will not turn on
    Problem Solver:
  • 20 Answers
I hate to be the bearer of bad news but you might have a corrosion problem which is common for those computers or you might have a blown capacitor maybe, so I would take the motherboard out if you know what your doing and check the board for any black spots.
Do you know what happened with the computer at all? Did you do something and than this started happening? Was the Computer given to you?
Hope I can help
Posted on Jan 07, 2009
Cpu fan can't run on dell dimension
You can clean or replace the fan.
Get the manual from www.dell.com/support
You can download it free and look up the fan repair instructions.
Hope this helps.
Mar 05, 2012 | Dell Dimension 2350 PC Desktop
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
My dell dimension computer won't turn on. When I push in the button, it only flashes orange and then won't turn on.
Plug the computer into a power strip that has an on/off switch. Turn the power strip on. Press the computer power on button to start as normal, but after after one second turn off the power strip switch just long enough for the fans on the computer to slow down, but the amber computer led doesn't turn off and then turn the power strip switch back on. Computer should start and run fine. Computer typically can be shut down for up to 5 minutes and restarted normally--any longer and you have to sue the power strip power switch routine again
Oct 25, 2010 | Computers & Internet
Orange flashing light on a dell dimenson 5150 computer won't start up
The orange flashing light on the power button is an indication of power supply failure.
Your Power supply unit needs to be replaced.
Aug 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 3000 flashing yellow light
Replace the power supply with a known working one. If it goes away then you know that the original power supply is bad.
If it doesn't go away with the new power supply then you know the motherboard is bad and would need to be replaced.
Jun 26, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
David Payne
David Payne
