Question about Sony KV-9PT50 Television
Can't get closed captioning to work
I went to menu and then to Set Up. Went to Closed Captioning. clicked on CC1 but it does not display. On screen instructions were to insert a number but whenever I do that I get out of menu.
  • 3130 Answers
SOURCE: I try to put the caption vision CC1, and it does not work
Is it reading or working on some channels? If it is your set is working correctly as not every channel has closed caption available on them. Good Luck
Posted on Jul 18, 2007
  • 395 Answers
SOURCE: closed caption on, but not working
do you have a cable box? is it a motarola box? is it HD box?
if the answer is yes to all of the above then leave the TV on and shut the power off on the cable box on the front of the box. then hit menu on the front of the box, an intrenal menu will come up. using the curser buttons (up/down) scroll to where it says "close caption : disable" use the curser buttons (left/ right) to highlight the disable the use the up/down curser to the "Enable" position now hit menu again then power to turn it back on.
you see close caption is not encoded thru Y, Pb, Pr cables nor is it thru HDMI and no set has decoding for closed caption thru this connection. so it has to be done thru the box.
Posted on Jan 21, 2008
SOURCE: closed caption for sony trintron analog tv
Closed Caption will not turn off. Model: Sony Trinitron
Posted on Sep 04, 2008
  • 6 Answers
SOURCE: Closed captioning used to work. Disconnected TV to
You need to use a remote control to fix this one. There are options, and some say different things. but there is always a seperate button for Closed Captioning on TV's.
Posted on Jul 16, 2009
  • 418 Answers
SOURCE: Can not get Close Caption to dispaly>
CC in the TV will only work while watching the TV's antenna or cable inputs; not the video inputs.
Posted on May 09, 2010
How do I turn off the closed captioning?
Press the closed captioning button a second time.
Mar 20, 2016 | LG 47LS4500 47 Inch 1080p LED LCD HDTV -...
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
How do you get rid of closed caption?
Depending of what model of TV you have, the option to turn off the Closed Captioning is usually found in the MAIN MENU under the heading of AUDIO OPTIONS.
Look in the AUDIO OPTIONS menu and try to find where it says CAPTION VISION, or CC1, or CC2, or XDS, or TEXT1, or something similar for the display setting, then switch that to OFF.
Otherwise look on your remote control for a button to turn off the Closed Captioning (CC).
It may be a button called DISPLAY, and you just press that repeatedly until DISPLAY OFF appears on the screen.
If you provide the exact MODEL NUMBER for your TV next time in your question, more precise instructions can be provided in order to help you out.
Good luck.
Mar 10, 2011 | Televison & Video
Okay, have Hitachi 1080 HD. Called several times to Customer Service but they couldnt help. Cannot get the words in English to appear on screen for hard of hearing.
Look in the tv menu for SET UP or AUDIO options.
Look for CAPTION VISION and set to CC1.
Now exit the menu screen.
Now use the INFO or DISPLAY button on the remote to activate the closed captioning.
It should say something like CC1 ON once you get it right.
That should be about it.
Note that not every single channel has closed captioning for every single show and that the words usually take a few seconds to show up on the screen when you change to a new channel.
Good luck, hope this helps. Keep us updated on your progress.
Jan 21, 2011 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
How do i get audio description of my tv
Check your menu settings. Look for CC1 or closed caption on mute.
That way when the volume is off closed captioning will turn on.
Some tv's have a setting to turn on closed captioning (possibly cc2) that will allow closed captioning while volume is still on.
Aug 08, 2010 | LG Televison & Video
Under captions setting what cc1 and tx1etc. mean?
the tx is a box with writing in it, whereas cc is closed captioning, which is just writing on the screen. if the tx is unavailable, you will get a black screen. try the cc if you want closed captioning. good luck!
Apr 01, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
How do you remove the subtitles?
Subtitles are controlled by 'CC". Closed Captioning. Look for a CC button on the remote or captioning.
Captioning usually is in the menu as well under 'settings'.
Closed captioning has several settings. OFF turns all captioning off. CC1, CC2, CC3 & CC4 are captioning styles. Text is for text channels.
Mar 31, 2010 | Toshiba 57H84 57" Rear Projection...
Have a black-out square appear on some channels especially FOX
Jan 22, 2009 | Broksonic TV
Black square image on screen
meknow is right I think. To turn off your closed captioning hopefully all you need to do is get into the setup menu. You didn't list what kind of TV you have so this is a generic solution. Go into menu and in a setup menu there will be a closed captioning way to select to turn the box off.
The reason sometimes you see it and sometimes you don't is because some programs have closed cationing and some don't.
And because you are only seeing a blank box and not closed captioning is because there are different closed captioning standards. CC1, CC2, etc.
So if you can find the menu item that allows you to turn off the closed captioning, it would be a good start to solving your problem.
Nov 04, 2008 | Televison & Video
Sony KV-9PT50 Television Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
