Question about Gateway M-6834 Notebook
My Gateway m-6834 won't turn on
I have a gateway M-6834. When i press the power button the blue light turns on and goes back off. It doesn't come on at all which means i'm not seeing anything.
Can you help me please?
  • Mark Robinson May 11, 2010
    try detaching the battery and booting from mains power only..
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Gateway NV78 laptop turned off and won't reboot.
So reformat a computer that can't access the hard drive, interesting trick. I believe the OP said the machine hangs in limbo with Power Lights on, I assumed the Lights are on, but no one is home, sort of like some of these solutions. Why am I not paid millions of dollars for being the smartest man alive?
Aug 12, 2012 | Gateway Computers & Internet
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
Notebook power button is blinking red when I try and turn in on. Plugged into ac adapter
sounds like bad adapter.red blinking light means dead battery.so if charger is bad it will not power the pc or charge it.
Oct 16, 2009 | Gateway M-6834 Notebook
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
GT5220 won't turn on
My motherboard was replaced twice by the gateway people. Luckily I bought it at costco and it has a two year warranty through them because gateway didn't want to deal with me until costco techies made them. I have the same model and had the same problem
Jun 24, 2009 | Gateway GT5220 PC Desktop
Red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Jun 12, 2009 | Gateway M-6834 Notebook
Gateway M-6834 laptop -- power blinks
Im having the same problem. did you find a solution?
May 14, 2009 | Gateway M-6834 Notebook
Gateway M-6834 Notebook Logo
484 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
