Question about Gaggia Classic Espresso Machine
Gaggia classic -no steam from spout
Machine heats and brews coffee but turbo frother does not emit any steam -have checked hole and cleaned it but still no steam
    Problem Solver:
  • 5 Answers
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Posted on Jan 14, 2009
    Novelist:
  • 137 Answers
If it is the case as mentioned from Clarincody than it is the best to look for resetable fuse for that place, you will be able to use it more than once.
Posted on Mar 28, 2009
Pump may be broke
Remove the frother nozzle: if its the early type with three hooks, slide the frother body down before trying to remove it. Disassemble the frother and clean the three holes in the end. If the holes are blocked, the steam can't escape. If it's not pushing hot water through the coffee holder, pull out the water reservoir, and remove and clean the grid plate assembly where the coffee holder clips in.
Feb 08, 2014 | Krups XP5220 Espresso Machine & Coffee...
No steam coming from frother
If you are getting hot water from the grouphead to make coffee then the nozzle at the end of the steamwand could be blocked, use a paperclip to clear. If the problem is not fixed after cleaning nozzle then machine need to be descaled.
Oct 02, 2011 | Gaggia Classic Espresso Machine
Gaggia Classic (3 months old). Suddenly there is steam only, no water flow.
If there is no water from the head then remove the screw and screen, then press brew button, if water flows clean shower, using a pair of plies hold screen over open flame, coffee will burn out of the small holes. If no water after trying above then remove the 2 allen wrench screws and carefully remove the diffuser and seat with spring, now try running the head, if water flows reassemble and you are back in busines, if no water descale machine.
Nov 25, 2010 | Gaggia Classic Espresso Machine
FOAM PROBLEM...with your Gaggia coffee machine? No foam?probably the little parts at the end of the turbo frother (plastic bush) was push in when you washed it. So, to repair it, take a wood pencil,...
I HAD A FOAM PROBLEM...with my Gaggia coffee machine. No foam. It was the little parts at the end of the turbo frother (plastic bush) witch was push in when I washed it. So, to repair it, I toke a wood pencil, introduce it gently by the other end and push out that little plastic thing, that's what makes the steam to foam the milk.
J.M. Coutu
Jan 28, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I have a gaggia classic. I've descaled it and kept it running well for a few years. It now won't let any water out of the coffee filter section - the frother is perfect, but no water is coming out of the...
Remove the screw and shower in the head, check shower for blockage, if it is covered with coffee, hold over an open flame to burn out coffee (easiest way to clean it). If it is clean and you can see through all holes then turn machine on and press brew button, if not water flow, then remove 2 allen wrench screws and check spring and valve(remove carefully) then try the brew button, if no water then blockage is on the inside of the machine use the pic below to clear it will be on the top of the head.
Jan 20, 2010 | Gaggia Classic Brushed Stainless Steel...
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Jan 14, 2009 | Gaggia Classic Espresso Machine
Airlock in new machine
I have a similar problem, I think. I get water through the steam thing, but not through the brew head. Not sure what to do either.
Oct 07, 2008 | Gaggia Classic Espresso Machine
Water Spout Leaks after Brewing Coffee
You have to replace the gasket in your steam valve, if you have a steam valve in plastic i recomend you to replace it with a steam valve in metal.
Best regards
/Mirran
Sep 04, 2008 | Saeco Incanto Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
947 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
