Question about HP Pavilion dv6000z Notebook
No DC Power To Laptop
My laptop was dropped by my 3 year old son. It landed on the power adapter and bent it. For months everything worked fine except having to find the "sweet spot" where the power adapter seemed to make contact (blue ring around plug lit up) One day it just stopped working. I purchased a new hp power adapter...still nothing. I then purchased the replacement power board (dc jack and usb on it) and replaced it....still nothing. I'm baffled
  • HP Master
  • 32,281 Answers
The problem is the input power socket on the laptop. It is either damaged, or the soldered connections on the connector has disconnected from the motherboard (eg formed a dryjoint).
It should not be too expensive to repair, or you can pull apart the laptop yourself and resolder the power connections. I suggest you use a temperature controlled soldering iron and ground yourself with a static strap for this repair.
Posted on Jan 07, 2009
I cant able to on my laptop when is not connected with ac adapter,but when is connected it starts power on but shows plug in not charging?please help me?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Dec 24, 2012 | Computers & Internet
Tip
How to troubleshoot your laptop at start
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead. What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
on Mar 27, 2010 | Computers & Internet
My laptop won't charge. I only had it for two months.. I think it is the battery not the charger... Will the warrenty cover that?
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 17, 2011 | Sylvania G-Netbook
My compaq c 581WM notebook pc won't start at all. A while ago it got pretty banged up but I got it fixed and it worked fine untill like 5 months after and from then it wouldn't charge or turn on...
Jul 21, 2011 | Compaq Computers & Internet
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
The old battery will not hold a charge when not plugged in so i bought a new battery. the battery came today in the mail and says "plugged in, not charging" and the battery light on the front is...
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
Hi, My son's Advent 4211-B notebook won't switch on. No power at all. Any idea what the problem could be?
Feb 07, 2011 | Microsoft Computers & Internet
Acer Aspire 7741Z - 4643 that is only 2 month old. It is plugged in, and recognizes that it is plugged in, but does NOT charge the battery. Please let me know what to do. Thanks, Not charging
Feb 06, 2011 | Acer Aspire One PC Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Plug it up w/o or w battery green lights comes on and then nothing Computer only 1 and couple months old help
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 16, 2010 | Acer Aspire One PC Notebook
HP Pavilion dv6000z Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
