Question about Samsung TXK2566 25" TV
Samsung tv I cannot adjust the volume on this tv by any regular means. Buttons on the tv or by using the remote simply temporarily shut off the tv. After you take your finger off the button the picture returns with no sound difference.
    Problem Solver:
  • 15 Answers
Have you tried replacing the tac switches?
Posted on Jun 23, 2007
SOURCE:
How do I get a Crosley 42" hi def tv to change
I can't speak with knowledge about the Crosley brand, but almost all regular TV brands have buttons on the side for Function or Menu On/Off, Volume +/-, and Channel +/-. The volume and channel buttons are used to navigate the menus and to adjust the settings.
If you can't work this out by experimenting with the buttons, or reading the user manual, then perhaps you should just go out and buy a universal remote that works the Crosley TV brand.
Hope this helps.
Sep 06, 2014 | Televison & Video
When I switch on my L24FED13 I get a speaker icon in top left with zero next to it, the remote does nothing after switching on
Sounds like the remote or the receiver may be faulty. The speaker icon with the zero means simply that the volume is turned down to zero.
When you press remote buttons, do you see a flashing light on the screen at all? Can you use the buttons on the screen itself to try and adjust the volume? You'd need to try these things first, so we know how to help you further.
Oct 28, 2013 | Computers & Internet
Been having sound problems for 6 months.. At first i could just adjust the volume up and down and it would come back on now it won"t come on at all. picture perfect just no sound. Tryed changing from...
ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
Mar 03, 2018 | Samsung PN58B540 58 in. Plasma HDTV
How could the ring volume be adjusted (turned down or off) on a samsung inkjet tel./fax SF-340 series?
Hi!
To adjust the ringer volume, simply press the left/right arrow buttons, the SF340 must be in standby mode.
Every time you push one of those buttons, the ringer volume will be changed down or up. Volume 0 means no ring.
Please let me know if it helped.
Aug 10, 2011 | Samsung SF-340 Plain Paper Inkjet Fax
Tv keeps shutting off with standby and lamp light blinking. what does this mean?
Good Day sir/maam, if your TV shuts off regularly, means that the power supply section is overloading, this may be due to faulty parts inside your TV, or either the AC mains in the community is to low or to high. If you want you can temporarily use a spare Auto voltage regulator with 500 watts, use it to levelize the AC main, if symptoms still persist, you may need to call for service. hope this helps. thanks
Oct 23, 2009 | Samsung HL-S5687W 56" HDTV
How do I adjust the sound on samsung soul
If it is ringtone sound:
Go to Settings, Phone Settings, Select Options, then Edit, then scroll down until you come to Volume, you can then adjust the sound.
If it is call sound:
You can do this when you are on the phone to someone. Above the Charger hole there are 2 buttons(looks like 1 button). Just simply adjust the sound to your prefrence.
If it is Key Volume:
Simply use the same buttons as you use for call sound but press these whilst you are not on the phone and adjust to your prefrence.
Hope this helped.
Oct 07, 2009 | Samsung U900 Soul Cellular Phone
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Samsum PLH403W service menu
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Feb 01, 2008 | Samsung PLH403W 40" Rear Projection...
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Samsung TXK2566 25" TV Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
