Question about Momo Design Logitech MOMO Racing Force Wheel and Pedal Set - 963282-0403 (9632820403NR)
Throttle cuts out.
When playing Nascar 2003 the engine of the car I'm racing seems to cut out. Is this an issue with the pedals? This is a brand new unit.
  • 15 Answers
Xc90 v8 chugs or cuts out when accelerating
try the throttle control electronics on the end of the throttle pedal as their is no cable but a electronic reostat control and when this plays up you get the symptoms you describe
Nov 18, 2012 | Cars & Trucks
Our engine light has come on 2003 windstar van. the oil and water pressure is fine. We were told to spray clean the throttle body. our engine size is 3.8 liter
Oil Level has nothing to do with a MIL Lamp on your dash
You have no way or reason to test for water pressure.
They only do that on race cars,in the NASCAR Cup Series
Spraying the throttle plate is a good idea,once a year
You have not said why your here !
What codes do you have?
What vehicle issues do you have?
What has been tested so far & how
Jul 17, 2011 | Ford Windstar Cars & Trucks
Lost Nascar Racing 2003 CD, have key code
u probbly have to buy another game or just torret the file
Mar 15, 2010 | Papyrus Nascar Racing 2003 Season for...
I have a 2001 Mercedes C240. When the engine is running with car stopped you can feel a bit of trembling. It also cuts off during driving and at slow speeds only. Like when I will the foot off the pedal...
The first thing you do is have the engine control module scanned for fault codes. I also suggest you buy a can of spray throttle valve cleaner and clean the throttle valve and the idle speed control valve.
Apr 21, 2017 | 2001 Mercedes-Benz C-Class
Pedals broken on xbox 360 MS wireless wheel
I've see a lot of posts where people have had issues with the Microsoft racing pedals not working properly. Usually the throttle just races away when it is suppose to be at idle. I had this problem and after taking apart the pedal set more than once to try and fix it - it's made so cheaply - I gave up.
So, if you want a good fix, here is what I did. I got a set of Madcats 2 pedals, which are X-box compatible (craigslist) - other pedal sets may work but then you would have to figure out the wiring on your own which took me considerable time NOTE: These do not have to be the Madcats pedal set from the force feedback type, just the standard pedal set will work.
I went to home depot and bought a wall phone jack. I then took the bottom off the Madcats pedals (the Phillips screws are under the square rubber pieces which you can peel off with a small blade - common screwdriver) and you will see there are 4 wires going to the cable that normally plugs into the MC2 wheel. Pop the face plate off from the phone jack but don't throw it away and cut the cable on the inside of the MC pedal set about 2" from the grommet. You can pull the grommet out of the slot and discard the cable. Carefully strip the insulation on the 4 wires (Brown, Yellow, Blue and White). I've done the hard part, which took me about 5 hours so here are the correct wire color match-ups. The phone jack has Green, Black, Red and Yellow wire hook-ups. Connect the MC-Yellow to PJ-Green; MC-Blue to PJ-Black; MC-Brown to PJ-Red;MC-White to PJ-Yellow. Now you can plug in the phone wire connection from the wheel into the phone jack and try out the MC Pedals. Much better? What I did next was cut a hole in the back of the MC pedal case (make sure it is not in-line with where the bottom plate weight goes. I used a hole saw just smaller than the phone jack and then used a razor knife to form a good fit fro the phone jack. Remember the face plate? Get yourself a good pair of sturdy Scissors and cut around the circle on the face plate. Now put the phone jack in the hole you made from the inside of the pedal housing and snap that little disk you just cut out from the face plate onto the phone jack from the outside of the pedal base. Now you may want to glue the phone jack in place on the inside of the pedal base just so it stays put. I used epoxy putty because it kneads like play-do and is easy to push on place. Also it sets up in just a few minutes. Now just put the bottom plate back on the MC pedals and put the screws back in. You will find that the MC pedals do not have the same problems that the Microsoft pedals did like the sticking throttle problem and they are much more responsive.
May 20, 2009 | Microsoft Wireless Race Wheel 2 for Xbox...
Computer game with no instructions or manual
hi ........
yes u can get them from
http://www.answers.com/topic/nascar-racing-2003-season
u can also check the manual in the installation disk
please comment!!! and give ur rating
Dec 28, 2008 | Sierra Online, Inc. NASCAR Racing: 2002...
Issue with throttle control on my 2003 Maxima
I discovered that its the throttle body sensor. Its not sensing the postion of the foot pedal. The throttle body has a sensor that is linked to your gas pedal via a cable. The spring that the repair man mentioned could be the issue. The sensor then communicates to the computer the position and then computer then applies fuel, the mass air sensor then will communicate to the computer and the computer will then allow more or less air to fuel ratio. So if your stomping on the gas and there is not any response, then your throttle body sensor is most likely going out.
Nov 21, 2008 | 2003 Nissan Maxima
Logitech nascar racing wheel ps2
Make sure the driver is correctly installed for the hardware. Also if for a game in the options menu should be something along the lines of controller or input, just change the input to the pedals
Nov 06, 2008 | Logitech NASCAR Racing (963339) Wheel And...
Momo Design Logitech MOMO Racing Force Wheel and Pedal Set - 963282-0403 (9632820403NR) Logo
116 people viewed this question
Top Momo Design Video Game Consoles & Games Experts
James Wishart
Are you a Momo Design Video Game Console and Game Expert? Answer questions, earn points and help others
