Question about Goodman Heating & Cooling
Goodman furnace is there a technical support line
  • 8,197 Answers
Consumer Affairs Address
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729.
Good Luck and Please rate fixya!
Posted on Jan 07, 2009
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Goodman furnace cacf030a2a fan seems to come in but no pilot light... Help??
might need to bleed the gas line at the furnace, if it has not ran in some time the gas gets weak and will not support the flame needed to keep the pilot light lit
Sep 16, 2015 | Goodman Heating & Cooling
Why would my goodman gas furnace leak water from the panel that the blower motor is attached to?
the only reason water would come out of your furnace is if you also have your AC in the same system, and the condensation line is not allowing the water to drain properly.
If the water only happens during cooling, clear the condensation line. If it is happening during a heating cycle you may have an improperly connected thermostat, a bad control board, etc...
Nov 16, 2014 | Goodman Heating & Cooling
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
I need a tax credit on line form for my new furnace
what you need is a letter from the manufacturer that states that your unit qualifies for the tax credit. try the manufacturers web site (click below) or where you got the furnace
goodman
Oct 07, 2009 | Goodman GMS90703BXA Heater
Goodman furnace was installed on its back- Problem?
The furnace can not be installed with the doors facing up. It will not work properly and yes it is dangerous. The unit needs to be flipped to its side, and the plenums and the ducts need to be changed around along with your Flue (vent) pipe, and gas line. HVAC-R Tech
Feb 04, 2009 | Goodman GMS90703BXA Heater
Need line set size for goodman ck-36-1a
If your running gas heat it's 5/8 3/8 tubing.If it's elec. heat it's 3/4 3/8 tubing. Etheirway 3/4 3/8 works for both. Use 6 wire for tstat from tstat to furnace or air handler, and you need is 2 wire from condensing unit [outside] to furnace or air handler or anything more than two.
Sep 26, 2008 | Goodman Heating & Cooling
Goodman Furnace
Inspect the venting system for sags or blockages. The added restriction could be adding to your issue.
Mar 29, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
134 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
