Question about Canon PIXMA MX310 All-In-One Printer
How to you work the fax because I can't find my book
I would like to put a title page but need help
I would like to print my fax details out if they went through
Do you put the print face down or up when sentding a fax
    Problem Solver:
  • 4 Answers
Depends on your machine usually up unless its a copier /fax then down on the copier surface...hope I helped a little...jer
Posted on Jan 08, 2009
  • threetyme66 Jan 09, 2009
    you can get an manual online or give me your email and i'll send you a copy of mine~Jer
When faxing documents on a Brother 525 fax machine do you put the item Face up or face down
If you have a Brother FAX-525DT, then place the document face down with the leading edge (top) down. The scan unit is on the bottom of the paper path for documents. The manual for the unit is available from Brother's EU division's support. The direct link is http://www.brother.com/pub/eur_fax_doc/fax515_525dt.pdf . The picture for how to position the document to be faxed is on page 55 (page 65 of the PDF).
I hope this helps.
Jan 27, 2016 | Brother Office Equipment & Supplies
Do I insert the paper I want to fax face up or face down?
Having no Operating Guide, I'd type a one line sample, make a note on the paper like "face-up" and put it in with the paper facing up and hit "print".
If it prints on that side you have your answer. If it prints on the backside, then put your papers in facing down.
Jun 20, 2011 | Lexmark F4270 Plain Paper Inkjet Fax
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
How do I align the cartridge after I replace it. The fax printed out a sheet and the lines are not straight. I went to tools...to align cartridge and then I am not sure how to adjust the lines
Follow below steps to complete alignment.
  • With the Cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place.
  • Close the cartridge compartment cover and control panel.
  • Press the Start/Enter button.
  • On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old
NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
  • An alignment page will print and 06 [01-11] will show on the display
  • Look at the alignment page and select the number under the straightest line, and then press that number on the keypad and then press Start/Enter .
Oct 17, 2010 | HP 1040 Plain Paper Inkjet Fax
Faxing instructions do you insert paper face up or face down
If you're putting it on the glass, it goes face down. If you're talking document feeder, look for the icon of a page. It will show printing with a corner curled (face up), or a blank page with lines on the curled part (face down).
For an example of what a face up icon looks like, check out the HP instructions for an HP machine here http://h10032.www1.hp.com/ctg/Manual/c01325508.pdf
That's the generic answer to a non-listed model number :-)
Carl
Feb 23, 2010 | HP Office Equipment & Supplies
Loading the paper in the fax on a 6480 all in one. Does the printing face up?
Faxes are sent print facing down. If you look closely on the plastic part where you put paper it shows you kinda folded paper showing print is down. Hope this helps.
Jan 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Whitch way does the paper go in for faxing ?
If your using the feeder on the top of the scanner, it should go face up. If you are faxing from the glass - face down.
Oct 29, 2009 | HP Officejet 6500 Wireless All-in-One...
How do you load document to send fax. With letter facing you or facing down. Model HP 920
There should be an icon on the device showing a rectangle and what appears to be a triangle on top of it. This is showing you a folded page. If there are no lines on the rectangle with lines on the triangle then you insert the page face down (print on page towards the device) if the rectangle has the lines and the triangle doesn't, you insert face up (print facing you while in the inserting into the machine)
If you have any more concerns address your owners manual, this can usually be found on a CD that came with your printer or at HP's support website.
Let us know if you have any other issues.
Apr 16, 2009 | HP 920 Plain Paper Fax
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Canon PIXMA MX310 All-In-One Printer Logo
87 people viewed this question
old marine
old marine
