Looking for Price and Availability on a DVD Drive, Model # RW5245LT ? If not available no more, a Substute drive number I can use.
What would it cost to purchase a styli/needle for Sherwood DEK7-U?
All you need to do is look at the cartridge and find the make and model number of it. Put that into google search and the information on the stylus should come up.
Jul 03, 2014 | Audio Players & Recorders
Need to replace DVD unit of 27hlv toshiba combo tv/DVD. DVD reads some discs but not others. This model is discontinued. Please advise.
The DVD drive on that unit will probably no longer be available for replacement from manufacturer but you can usually find a good working drive on Ebay at a reasonable price. just type in model number and see if one comes up. Another place to check would be shopjimmy.com
Sep 09, 2011 | Toshiba Televison & Video
The DVD drawer will not open unless a disc is in the drive. When the drawer would not open I took the cover off the player. The DRC8295N is a VCR-DVD/R RW player recorder. The DVD drive will record on...
The problem isn't with the motor being too weak, but the belt which the motor drives. I had the EXACT problem just as you described. What I did was I took off the belt and cleaned it with rubbing alcohol because apparently the belt picked up some of the grease from the gears and wouldn't rotate when the motor spinned. This belt actually pulls down the mechanism, on which the CD sits, from the magnet. So, just clean the belt and you should be good to go. If the belt is very loose, you might need to replace it.
Feb 14, 2011 | RCA DRC8295N DVD Recorder/VCR
Internal dvd/cd-rom
Looks like the answer is yes. Call to be sure. For prices and availability of parts and upgrades for this system, call 1-800-357-3355. Give them the service tag number and they will be able to tell you for sure.
Assembly 24X CD-RW/DVD Combo Drive Usually Ships 3-4 DaysManufacturer Part# R3117 Dell Part# R3117
Starting Price spacer.gif $109.95
Apr 14, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
The projection bulb blew up in my Philips 60PP9363H/17. Repair man says this model takes no bulb/lamp. The shattered glass is in my tv from a bulb/lamp so it has to take one. I need to know what part...
Vendor nap.jpg Part Number 483513127193 Description Crt P16ltg Substitute Part n/a Estimated Weight 1 Lbs. Availability by Warehouse Atlanta, Ga 3 Las Vegas, NV 1 Baltimore, MD 1 Miami, FL 1
Total Availability 6 Estimated Ship Date in stock Core Price 0.00 Part Price 303.01 Total Price 303.01
There is something very bad if you have broken glass on the inside of this TV, it is a CRT rear-projection. The tubes might be available, but the labor will be over $300 plus the parts, plus, this TV may have issues in the future. I suggest looking for a 50" LCD or Plasma, Vizio is great because it is LG parts inside, but definitely get the extended warranty.
I hope this helps
Jul 25, 2009 | Philips 60PP9363 60" Rear Projection...
I have Dell Inspiron 5160 laptop. I want ot replace the CD-RW/DVD with a CD burner. What should I be looking for or is it better to go with an external DVD burner?
Well a CD-RW/DVD ROM is a CD burner so you really dont need to replace it. Unless you meant replace it with a DVD burner then...
The best thing you can do is go to the Dell website and search your notebook/model number and look for the upgrade drive and buy it from them. If its to expensive search ebay or the web with the info you found on the Dell website (combo drive name + model number) and find one for a cheaper price.
Jan 04, 2009 | Dell Inspiron 5160 8X DVD+RW, IDE - R5024...
Hi, i am trying to buy a Pump Water Connector for my Samsung No Frost Fridge Freezer. Thanks
i can help are you looking for a water valve, if so you need to get your model # usually on inside of fresh food cabinet on the inside and call around for prices and availability. we could order for you and ship it to you with a model #. feel free to call for price @ availability
ALL BRANDS APPLIANCE REPAIR + PARTS
5008 W. LINEBAUGH AVE # 8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair.com
EMAIL customerservice@allbrandsappliancerepair.com
Jul 11, 2008 | Samsung Refrigerators
Telex Spinwise CD-DVD Duplicator - Source Drive Read Disk Error
i have a telex Spin dupilactor Cat/Model # 301931000*4-16D and i am Looking for a price to insure it. a replacement price
Oct 19, 2007 | Telex SpinWise 7-824D (301689000)...
Internal dvd drive
You will find almost ANY standard form factor DVD will fit, once you open up the case you will see a fairly standard type of DVD.. They are all fairly much the same with just maybe differing mounts etc, Take the old DVD out and get the Manufacturer, Type and Number off it, and then Google for a price and availability.. then take note of the specs, once armed with what it is, you can then shop around for the best deal.
Aug 31, 2007 | Dell Dimension 4500 PC Desktop
Televison & Video Logo
380 people viewed this question
Top Televison & Video Experts
Electro Med Services...
