Question about Nintendo DS Lite - Onyx
Bottom screen i have just changed the top screen now the bottom is not woorking properley the touch screen is not working help please
  • John Andriessen May 11, 2010
    Is this still a problem?
A wire has disconnected, you have to take ds apart again (not fully) just so you have access to motherboard with black and white wires showing. look to where the black wire is fixed on and below that to the edge of the board you will see a tiny piece of see-through plastic with black lines through it, (mine had come loose and i had fastened ds up whilst it was curved underneath board). you should also see there a slot approx 2mm at most with 3 / 4 bronze/gold prongs ( very much like smaller version of the large wide wires and slots they fasten into) you dont have to flip anything up to get this wire in or out, just slot in carefully (i used tweezers) as far as will go, making sure you dont disturb placement of any other wires. now put shell back on and before you put screws in just switch ds on to see if problem is solved. hopefully ! mine worked fine after this.
Posted on May 07, 2009
Top screen not as bright as bottom screen
You can't change the brightness of the top screen but you can change the brightness of the bottom screen to match/ suit your needs.
Whilst the DS lite is off tke out any games that may be in it, Turn the unit on and touch the screen to take you to the main menu screen. at the bottom left of the menu screen you will see a little sun picture... tap that to change the brightness of the bottom screen, there are 4 stages of brightness to choose from.
Hope this hels, any further questions please feel free to contct me via my profile page.
Feb 24, 2010 | Nintendo DS Lite
Ds top screen turns white then shuts off.
the cables need to be inserted Fully And squarely/evenly.
Also ensure The Tabs are locked Down correctly.
If none of this Works, you may have a blown On-Board Fuse.
I believe these Are Known As F1 And F2.
Mike @ Compurepair.
Aug 19, 2009 | Nintendo DS Console
Samsung tocco touch screen not working
The software of the phone must have gone corrupt. Take it to the authorized person and may also have to change your scren curcuit or the whole software.
Aug 14, 2009 | Samsung Cell Phones
On my Tissot t-touch expert, i need to know how to change
1. touch middle of screen till you see 24h Cm or 12h Cm
2. press middle button
3. top button changes Cm to Fft (celcius meters to farenheit feet)
4. bottom button changes from 12h clock to 24h clock
Apr 05, 2009 | Tissot T-Touch T33759851
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Nokia 6085 has a blue screen
i have repaired this problem time after time you need to replace the flexcable which is located inside the phone between the top and bottom of the phone the problem is that these phones are very poorly made and the cable inside gets crunched up with opening and shuting of the phone its very easy to replace and change and with ebay you can find the cable for around 4 pounds inc postage if you need help opening the phone please email i have had around 10 of these phones to fix and only 1 out of the 10 the screen needed replacing change the cable first its cheapest option! hope this helps all!
Jul 04, 2008 | Nokia 5200 Cellular Phone
Touch screen doesn't light up
Your problem is with the LCD behind the touch screen. The bottom scren on your DS is actually two screens. An LCD and a touch screen on top of it. Either your cable has come loose inside the DS or the LCD is possibly bad. This can be fixed.
The other option is that the electronics feeding the LCD have gone bad in which case you might as well buy a new DS. But check the screen first.
If the DS is under a year old you can send it to Nintendo for free repair.
Mar 04, 2008 | Nintendo DS Console
Problem with color
Replace convergence STK IC's,then realign to factory spec using service literature fo info.
Sep 29, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Put in new top screen, now bottom touch screen unresponsive
I know you replaced both top and bottom, and I am assuming that you placed the touch screen as well? it would be the touchscreen that is not working or you did not connect right. connie
Aug 17, 2007 | Nintendo DS Lite Console
Nintendo DS Lite - Onyx Logo
159 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
