Question about Alesis Multimix 8 USB 8-Channel Mixer Spdif System
My alesis multimix 8 isnt recieving a signal from my mic(mxl 990)
I have the mixer usb connected to my pc, the recording program i use identifies the mixer. the mixer doesnt identify the mic. the mic is plugged in the mic1 slot but i speak into the mic and the mixer doesnt light up.
3 Suggested Answers
SOURCE: wont install in my vist computer
I have the same prolem
Can everybody help us please
Posted on Aug 27, 2008
SOURCE: Alesis Multimix 8 Audio driver wont load
the mixer does not work damn that stuff.
Posted on Jan 30, 2009
Anybody knows mxl 990 works with behinger usb 302 mixer??
The user manual says Phantom Powered Mic input which means you should be able to use a condenser microphone requireing Phantom Power.
Mar 24, 2013 | MXL 990 Professional Microphone
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
Clip light on Multimix 12 Firewire always on
I have just gotten the same problem. In my case it worked fine for almost three years and one today I turned it on and this loud humming noise + the red clip light always on appeared. When I hit solo button on channels 9-16 the humming disappeares but the light would not go away. With solo on humming get louder on the mic channels individually (1-8). I am puzzled... No solution so far
Sep 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
I have a MXL 990 studio mic which I recorded one no longerworks
Are you using the original cable for the mike? In order to use phantom power the XLR connectors have to be wired in balanced configuration. Pins 1,2 and 3 must be wired separately. If you use a cable with 1and 3 connected you could damage the phantom power supply and in some cases the microphone.
Aug 19, 2009 | Marshall MXL990 Professional Microphone
Alesis Multimix 8 USB won't be recognized
There are NO drivers to be installed for this device. Plug in the usb to the device, and the PC once the PC is running turn on the mixer. XP should inform you that a USB Audio Device has been found & installed. Any software you use for rec'ing will let you choose what sound device to use, select USB Audio Codec.
May 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Clip signal on Alesis multimix 12 USB - no inputs!
eugene_m has a solution. You have to replace 2 capacitors.
Apr 12, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Can't operate my MXL 990
If it is an MXL 990 Condenser that comes in the grey case with a shockmount and a black hard mount I can solve your problem. (If it is USB I know nothing about that unit).
This MXL 990 microphone MUST have 48v phantom power in order to operate. If you aren't familiar with the term phantom power read the first link:
Phantom power -
MXL User Guide -
If yours is one of the older MXL 990's it should have an XLR connector on the bottom -
XLR Defined -
Your mixer (I am guessing its a Peavey, Tascam, Mackie) or something entry level like that may or may not have phantom power. I am guessing not. But if it does, it will have a switch that says 48v phantom power and most likely a green or red LED next to it to show you when its on. This mic will NOT work without phantom power.
Best suggestion: Verify that your mic is the MXL 990 Condenser, if it is it needs 48v phantom power. Check your mixer and see if it has 48v phantom power. The only computer soundcard that I know of that is used by a lot of folks is the M-Audio Delta 1010LT. It has XLR inputs but NO phantom power on it.
There's your answer.
Feb 09, 2009 | MXL 990s Professional Microphone
Multimix 8 USB
sounds like you ports on your computer got all messed up. you should call tech support on you computer and they can tell you how to fix it.
Jun 22, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
Alesis Multimix 8 USB 8-Channel Mixer Spdif System Logo
Top Alesis Audio Players & Recorders Experts
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
